r03 or r16.....need help..
Posted: Sun May 03, 2009 10:33 pm
by blueticktx
alrite fells i have the rough idle thing goin on got an 06.I just changed fuel filter and cleaned air filter no luck still rough....Secondly, whats the classic sign of a bad injector have had one engine light come on tuner did not read went ahead and cleared it..have had it on the performance tune 4 about a week now..please help...
Posted: Mon May 04, 2009 8:19 am
by kw5.9
if you have a '06 you need version 9r 03 and do a reinstall by going in to options trouble shooting and and the idle shoud smooth out and i had injectors go bad and predator couldnt read either....so do the key cycle trick to see what cel you got.
Posted: Mon May 04, 2009 8:42 pm
by blueticktx
tried the key cycle trick got nothin..explain is there a proper way to do it.....
Posted: Tue May 05, 2009 10:40 pm
by dunejunkie
had same problem with mine all of a sudden, took it to the shop and #1 injector was bad. replaced injector and it runs smooth again, well as smooth as a diesel can. i guess in 06 injectors were a common problem
Posted: Wed May 06, 2009 9:12 am
by johan
Yeah for some reason 06's seems to display the injector problem more than any year.
