Help!! Extreme Power Puck Install Questions.
- 2006megacab
I have a 2006 5.9 cummins. I'm trying to install the extreme power puck on it. I'm having problems with figureing out where everything plugs in. I don't want to mess anything up. Any help would be GREATLY appreciated. Pics would be really great. Thanks in advance!!
MaxDiabloSport
RE: Help!! Extreme Power Puck Install Questions.
2006megacab
Send me a email ([email protected]) and i will reply with some helpful pictures. Generally what you want to do is locate your vehicle's valve cover, which is on the driver's side of your engine compartment. Just beside the valve cover you will find a blue sealed plug, this is your MAP sensor. Just in front of your MAP sensor you will find you Fuel Pressure Sensor. Disconnect both of those plugs and connect in the Extreme PowerPuck harness(make sure you are connecting the harness correctly as it will also fit "reverse" and cause a check engine light to appear). I found in this application a good place to mount the puck itself (so the harness has plenty of room) is on top of the black plastic fuse box in between your washer fluid tank and battery. Send me a email and i will be sure to send you some helpful (hopefully) pictures.
- 2006megacab
Sorry, I figured it out. It was a piece of cake install once I actually looked under the hood. I was just a little worried about doing it myself, cause I couldn't find any install articles online 4 it.
1 more question. Will it hurt any thing running the predator on the non stacked rkl tune with the power puck?
06 Mega, Predator/Extreme Power Puck, AFE Stage 2 intake, CFM+ intake manifold, Heater grid delete, 7" Dual Stacks, BD Diesel exhaust manifold, BD Diesel Tranny, BD Diesel Converter, BD Diesel HD Flexplate, AutoMeter Gauges
Well, the stack tunes have a bit less pressure commanded, so they work a bit better with the EPP, but you can try them to see what you prefer.
