'07 Charger R/T rear O2 sensors
kissankill
Post by kissankill »
You guys make a awesome product. Am running the 93 oct CAI with the standard mods (MDS off, thank you for that one especially!), shift points increased, fan speeds lower (180 thermostat installed). Read answer about EGR disable, how about the rear O2 sensors. What does that accomplish? Also, it has been awhile since I have done anything with cars (last performance vehicle was a '68 Firebird Sprint) and was wondering...not to mess with rear end ratio unless gears swapped out..correct?
Car is '07 Charger R/T with 345 HEMI. Using the U7135 Predator with v.9r17 installed [/i]
'07 Charger R/T 345 HEMI: 91 CAI Tune w/ 93 gas only (modified); 180 T-stat; CAI; Catch Can; Lost "Suitcase" added headers
RE:
Only need to disable O2s or EGR if you have removed the cats or the EGR system from the car.
Same for the gears, only change if they have been swapped out...
kissankill
Thanks for the quick reply.
