Rough idle
Rough idle
I have a 2007 with the 5.9 and i have mine set on the tow setting and it has one nasty idle. I have changed it through all the settings and its the same thing. I ended up taking it out cause i know it can't be good for the motor. The fuel filter is new so i know thats not the problem. If someone has a solution for this problem please let me know.
- duallydave
RE: Rough idle
do u have the newest update from here,if not try that first
04 l/box.predator quad race x2 cammander.bhaf.6spd stick.
the lastest revision smoothed my idle, not 100% but alot better! After u load the new tune in the tool off the computer, you have to install it throught the options menu. You should be fine after that.
Ram 2500 2007.5,5.9ctd,6spd,4X4,predator,puck,Amsoil air filter, AME amsoil, straight pipe turbo back,silencer stolen,quadzilla fooler
click on the support tab at top, then click on down loads, then fill out the info and for the U7131 download the 9rv03, I have never done it there is a guy in San antonio TX that does it for me for $25.00. since I dont have the cords.
Good Luck
Good Luck
I have the same issues. Have had the programmer for 3 years now. Everytime there is a new revision or I add something to my truck I check to see if the rough idle will go away. It hasn't yet. I don't use it anymore which is unfortunate because the power and throttle response is awesome but my truck sounds terrible. Especially at high idle. I have my fingers crossed that one day it will be fixed.
04.5 Dodge 3500, 3" BDS lift, 35" tires, Diablosport, ATS Aurora 3000 turbo, FASS 95/150, 60HP nozzles, AFE stage I w/torque tube, 4" exhaust w/Aero muffler, ATS exhaust manifold, ATS arcflow, ATS rear diff. cover, FS2500, NADP "Race" transmission
