Bad Numbers - Chally SRT8 w/6M
Predator Part Number: Will update when I get home
Predator Revision: Will update when I get home
2009 Dodge Challenger SRT-8 (M6)
I read the thread in the announcement, and commented there, but thought I might get more attention with an actual post of the concern.
I have an 09 Challenger SRT-8 with 6spd manual w/ the following mods:
1. AFE stage2 CAI w/ heat shield
2. Jet 180 Thermostat
3. BT Oil Catch Can
4. Magnaflow high flow cats with 3" tubes
5. Magnaflow 3" Competition Catback Exhaust w/ X-pipe
6. Diablo Predator
I took it to have a CMR done, and when they ran the car the first time to get the base line the numbers where:
379whp - 371ftlbs
Conditions: OAT~78, IAT~80, RH~45%, 93octane fuel, Oil changed week prior with Mobil 0W40, 1800 miles on the odometer
The tuner then tried to do what he could and the best he pulled was:
381whp - 373ftlbs
What is up with these numbers? I don't know how knowledgable the tuner is with Hemi's (primarily tunes Corvettes and Camaros), but the shop was building a twin turbo SRT-8 Challenger.
3. BT Oil Catch Can
6. Diablo Predator
379whp - 371ftlbs
381whp - 373ftlbs
RE: Bad Numbers - Chally SRT8 w/6M
Do you have a dyno chart of before and after? Did your overall powerband increase?
I don't give much credit to peak numbers to begin with. If your overall powerband has increased then I'm inclined to say the tune was successful and there isn't a problem...
How does it feel compared to previously?
Re: RE: Bad Numbers - Chally SRT8 w/6M
Thats the biggest question.NickLovin wrote:.
Please post the dyno graphs, and get some logs to see if there is any KR present.
Did the tuner mention anything about Knock?
Did you have good quality fuel in the tank?
Was this a custom tune done with CMR or the canned tune, or adjustments made through the Predator to the canned tunes?
- Compared to previously, the same, maybe a little smoother or when I rev the engine, a little more popping in the exhaust, but not much.mikel wrote:Thats the biggest question.NickLovin wrote:.
- When I get home I will scan and upload the Dyno sheet, but if memory serves me, the lines seemed to be relatively close to one another.
- The tuner did not mention anything about knock, he did say that the left bank was running at idle 13%, the right bank was at 17%. He tuned those to 1% and 1.5% at idle.
- I used BP 93 Octane
- I do not know if he used CMR or the canned tune, I will call them and ask what he used.
See what he says... Might be time to find a different tuner...Raszaron wrote:- Compared to previously, the same, maybe a little smoother or when I rev the engine, a little more popping in the exhaust, but not much.mikel wrote:Thats the biggest question.NickLovin wrote:.
RE: Re: RE: Bad Numbers - Chally SRT8 w/6M
I have seen the srt's be lower on power with lower miles on the motor, i would run it again after you have 5k miles on the odo, should make considerably more power when it has loosened up a bit.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
Thanks johan, Here is the info off of my Predator (srl#241493, PCM#68004308AF). I took the car out and added ran a diagnostic, watch and record. I will try to dl it in a little bit.
Did I put the log in correctly, and because I am not even an apprentice to tuning, what are we seeing? It appears that the knock goes crazy a few times, but settles out, as it should, when steady cruising. WOT looks to be the suspect at best, and I do have a catch can on the car. My tuner (if I should say that) did say that he only noticed 1 to 1.5 on the knock. Once again, I don't know what the range is or should be. Your help is greatly appreciated.
Re: RE: Re: RE: Bad Numbers - Chally SRT8 w/6M
You got it, I had a customer come to me with only 5K on the odo, the best we could squeeze out of it was 379hp on a dynojet 224. Guys (not Mike) don't get too wrapped up with peak #'s I would focus on the power under the curve-that is where the engine will spend most of the time. On the Chally I tuned which only made 379 we picked up 20-25 hp and equal torque average through the powerband. If you look at that then the gains aren't really that bad.-jjohan wrote:I have seen the srt's be lower on power with lower miles on the motor, i would run it again after you have 5k miles on the odo, should make considerably more power when it has loosened up a bit.
www.hensonperformance.com
205-531-0598
205-531-0598
RE: Re: RE: Re: RE: Bad Numbers - Chally SRT8 w/6M
Here is the response that I received from the tuner.
Yes I was monitoring knock retard. It was only pulling about 1-1.5 degrees, and just for a short burst. I can tell you there's not 50 hp in the tune. There's not that in pretty much any N/A tune.
I will try to upload the file after I zip it.
Thanks for the input jah81592. I am comparing the numbers of the what Diablo got on their SRT8 to that of of mine with similiar mods. Just wondering what the cause of difference is. I will also try to scan and upload the dyno graph, unfortunately it is black and white. Plus there isn't much difference between the two sets of lines.
Different dynos first of all, different weather, different cars....all are variables that mean you can not nor should not try to compare dyno numbers unless they are on the same dyno, on the same day....
