2003 f-250 6.0L CAID ARZ2AH00, VXAP2N2, TQAU0N5
gatorbryan
I have a 03 ford f-250 6.0L. Took the truck in for some injector work and they flashed my cpu. Tried to upload 65hp and 100hp performance packages with the following CAID #'s ARZ2AH00, VXAP2N2, TQAU0N5. I know updates are in work and should be out soon. Just want to make sure they are for my problem as well. Thanks, Bryan
RE: 2003 f-250 6.0L CAID ARZ2AH00, VXAP2N2, TQAU0N5
Yes, it is the VXAP2N2 causing the issue, the new revision will add support for this.
gatorbryan
Re: RE: 2003 f-250 6.0L CAID ARZ2AH00, VXAP2N2, TQAU0N5
When will the revision be ready? Or can i just not find it?mikel wrote:Yes, it is the VXAP2N2 causing the issue, the new revision will add support for this.
thanks Bryan.
It should be done in the next week or two.gatorbryan wrote:When will the revision be ready? Or can i just not find it?mikel wrote:Yes, it is the VXAP2N2 causing the issue, the new revision will add support for this.
thanks Bryan.
