srt-4 rev limiter in neutral not working?
Posted: Fri Jun 26, 2009 5:15 am
by roniwan
tried to adjust my rev limiter in neutral to 3300 rpmswith no luck why is this?
rev limiter in drive seems to work fine
RE: srt-4 rev limiter in neutral not working?
Posted: Fri Jun 26, 2009 2:26 pm
by gizmodo
That isn't something you can set for the SRT-4. The PCM doesn't know when the car is in neutral.
Posted: Fri Jun 26, 2009 5:25 pm
by roniwan
well I just imagined that if the car its 0 mph it will asumes its in neutral and the neutral rev limit will be activaded so you can use it as a 2-step
Re: RE: srt-4 rev limiter in neutral not working?
Posted: Fri Jun 26, 2009 5:42 pm
by duster360
roniwan wrote:well I just imagined that if the car its 0 mph it will asumes its in neutral and the neutral rev limit will be activaded so you can use it as a 2-step
Nope, it doesn't work
RE: Re: RE: srt-4 rev limiter in neutral not working?
Posted: Mon Jun 29, 2009 11:05 am
by 04eblue
That would be something usefull though if it could be done.
