U7164 update progress
We will start a new thread so I can easily focus on everyone and anyone's questions about this update. This update is primarily focused on those who have the cal ID's:
87ua 14c204 cf
7u7a 14c337 ab
The update will correct all the erratic shifting, poor mileage, Regen and general performance problems. In regards to those who are getting a trouble code clearing problem, the one that says unit 2 failed to clear, I believe i may have a solution for it but probably won't know for sure until you guys get to try it. Tunes are made but my engineers are tied up at the moment with another issue. Once they can get back to me I will begin extensively testing the new tunes and try and find any bugs. If there was an issue here that you have not heard me address, you are more then welcome to shoot me and email or post it up on here.
87ua 14c204 cf
7u7a 14c337 ab
Don
2002 WS6
2002 WS6
RE: U7164 update progress
Thanks for the update Don. That's the communication we were expecting to begin with. Even if it takes longer, at least we know what's up.
Not a problem herb. I believe with that unit 2 failed to erase is that in the code for predator it is not asking the tcm for codes, hence the unit 2 failed to erase. Just one more problem Ill need to take a look at before this guys released. Not really too big of an issue though. I assume your probably all getting tcm codes because of the erratic shifting from the extreme tune...makes sense. Herb as far as your code goes, i believe it might be associated with a map table in the tunes, it was alittle wacky so i fixed that. We'll see if that fixes your problem if it does great, if not ill have to look into it alittle further, maybe write you some custom stuff until we can hopefully alleviate the problem.
Don
2002 WS6
2002 WS6
Morning Don,
Just wanted to give you an update on my programmer. Still having issues with the mileage, shifting, surging and dead throttle.
The cal id's are: 8U7A-14C204-FC
8C3A-14C337-CA
Thanks for your help with these issues.
Bill
8C3A-14C337-CA
Bill
working on them hopefully today, looks like alex has some free time to look it over with me.
Don
2002 WS6
2002 WS6
Hi Don,
Looking for some help in your update progress.
my tool:
Serial: D00C3A8
Version: 9T10D
Cal ID: Unit 1- 8C3A-14C204-ACF
Unit 2- 8C3A-14C337-DB
My Truck: 2009 6.4 Harley Davidson F450, Built in Feb 09.
My Problem: Feature Not Supported.
This is hubbys truck, and he is pissed to say the least because he cannot use the diablo!! Any Help in Update progress (even if it would load into the truck with the irratic shifting and lousy mileage issues) would be good at this time LOL! Thanks so much for your time and effort.
my tool:
Serial: D00C3A8
Version: 9T10D
I'll cross my fingers that we can finally be done with this. Now if you wanted to send me an emulator for those pesky emissions and pressure sensors so i can put in a delete pipe, I promise I'll only drive offroad from now on. I'll even sign a waiver.....
F2504myTIGE
