Missing Options under Diagnostic Menu
str5010
Post by str5010 »
2009 Challenger SRT 6 Speed, 2009 Charger SRT
U7135-current update
I am having an issue with two predators I am using. There seems to be missing options under the Diagnostic menu. I have been looking at the U7135 User manual and it shows that there should be a few more options under that menu than I have. There is no option for real time streaming or log play back. When I click on Real Time Data, it does not ask me what speed rate I wish to datalog the parameters at and there is no where to view the different groupings or parameters such as "gas acceleration wot". My Diagnostic menu only has three options where as the user manual shows that there should be five options. There is a note in the user manual that says when switching from one vehicle to another you must reset live table values however I also do not have that option under the Troubleshooting menu.
I had to call Diablosport upon starting both Predators which I purchased new because the main menu did not list the option for "Performance Tunes". The first option on the main menu was "Custom Tune" which had to be erased and reset before I could access the four standard "Diablo Performance Tunes". I was told that even though my predators were suppose to be new, they must have been used previously. Could my current lack of options be related to this?
RE: Missing Options under Diagnostic Menu
I have since figured out that the tools were not used, it was an issue with the way they were programmed from scratch, so they should have been brand new.
As for your menu changes, these menus have changed countless times over the years, it is normal.
str5010
Re: RE: Missing Options under Diagnostic Menu
Post by str5010 »
mikel wrote:I have since figured out that the tools were not used, it was an issue with the way they were programmed from scratch, so they should have been brand new.
So you are saying that there are no longer grouped parameters for different situations such as wide open throttle, that can be monitored? And my unit can't stream live data to my computer? I would hope my predator can stream live to the computer for datalogging since that is one of the major reasons I purchased it.
RE: Re: RE: Missing Options under Diagnostic Menu
There are still tons of PIDs and you can certainly stream live data.
Live streaming is done with the tool on the main menu and connected to the Dataviewer program.
str5010
Re: RE: Re: RE: Missing Options under Diagnostic Menu
Post by str5010 »
mikel wrote:There are still tons of PIDs and you can certainly stream live data.
Thanks for the quick response. I will try connecting this way when I get back from work. I see your user manual hasn't been updated for almost 2 years. You might want to update the manual for the new menus/operations since they see to have changed.
