After Appling tune I can not restore original backup
I just purchased a used U7131 and ofcourse took it straight to my truck. I applied a tune and everything seemed to go well. After a few days I want to place the original backup on my truck and it tells me that it is not able to restore the backup. Is there something I can do?
RE: Can not update tuner or apply tune
Give our tech guys a call...
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
After a quick call to support all is well.
what was the fix? I have the exact same problem. I loaded my tune in a year ago and attempted to restore to factory. I got the same message. I also loaded in the tow tune and tried to restore it again and got the same " can not restore message"
06 5.9 megacab 6spd 2wd
Aberdeen Wa
Aberdeen Wa
I too had the same problem. Tech support said to install the stock tune from the predator. What a disappointment that was. Went from 17-18 intown and 21 hwy(1750 rpm with stock tires) to a dismall 16 intown, 19 hwy. Knowing others are experiencing the same issue, it now becomes apparent that the predator has a gliche. Tech people at Diablo please fix this problem and duplicate the factory tune.
DWilson357
Tery Options/troubleshooting/restore original backupDWilson357 wrote:What process did you use to install the stock tune. That is my whole problem, I can't install the stock tune per the message "unable to restore backup." I can install any of the 4 tunes except the backup.
