Page 1 of 3
First datalog, what's it telling me
Posted: Tue Sep 01, 2009 10:28 pm
by JackFlash
I just did my first data log on my 09 challenger 5.7 today. I would like to know what it is telling me, and if there is anything you guys can see that should be adjusted. My ST knock is a little high, I think. Thanks for all the help and comments.
RE: First datalog, what
Posted: Wed Sep 02, 2009 1:56 pm
by JQ3
Won't open.
Posted: Wed Sep 02, 2009 2:01 pm
by JackFlash
how do I upload so it will? I just used the upload file tool for the post and went straight to the log file itself.
Posted: Wed Sep 02, 2009 2:41 pm
by Cruisin1966
A lot of us are having to host the log files on other servers. Megaupload.com should work. Then post up the URL to the file.
Re: RE: First datalog, what
Posted: Wed Sep 02, 2009 3:08 pm
by JackFlash
Cruisin1966 wrote:A lot of us are having to host the log files on other servers. Megaupload.com should work. Then post up the URL to the file.
I can't figure out how to use that site either.
As far as ST knock, I am getting 4.500 between 5000-6000rpm. Anything under 5000 is mostly "0". I think that is my main concern to be looking at?
LT knock is "0" always.
RE: Re: RE: First datalog, what
Posted: Wed Sep 02, 2009 4:47 pm
by JackFlash
Here is a link to my log file...hope this one works.
http://www.megaupload.com/?d=OP0C660Z
Posted: Wed Sep 02, 2009 8:39 pm
by Cruisin1966
That worked. Try adding 5% to the WOT Fuel in each of the 4000-4800 and 5000-7000 rpm ranges and log again. Perhaps next log you could add Accelerator Pedal Position % as well????
Posted: Wed Sep 02, 2009 8:50 pm
by JackFlash
Thanks man!!! Throttle blade position is not the same? Maybe I will have time tonight to do another one.
Posted: Wed Sep 02, 2009 10:18 pm
by JackFlash
This log is with 5% more fuel, w/accelerator pedal position
It looks like 4000-4800 is good and 5000-7000 could use more? I look forward to hearing what you have to say.
http://www.megaupload.com/?d=88KXF9B9
Posted: Wed Sep 02, 2009 10:40 pm
by Cruisin1966
I see a lot of ST knk while cruising, strange. Anyway, I'd probably go with the following:
5% : 0-3800
10% : 4000-4800
10% : 5000-7000
Try these and then log again. See if you can't find the PID called "Accelerator Pedal Position" to replace the two you did use.
Posted: Wed Sep 02, 2009 10:49 pm
by JackFlash
Will do!!! Thank you for all your help!!
Posted: Thu Sep 03, 2009 3:36 pm
by JackFlash
Well, here is the log with the 5-10-10 settings. I turned on everything that had to do with throttle position. Hopefully I got the right one on for you. Looks like it is getting better! By the way, this is a custom dyno tune we are working on that I paid to have done.
http://www.megaupload.com/?d=8AZCIQYA
Posted: Thu Sep 03, 2009 6:11 pm
by Cruisin1966
Seriously? It's a CMR and you're needing to jack with it? Holy!!!
Re: RE: Re: RE: First datalog, what
Posted: Thu Sep 03, 2009 6:17 pm
by JackFlash
Cruisin1966 wrote:Seriously? It's a CMR and you're needing to jack with it? Holy!!!
YUP!!! I am going to send this thread to the tuner when we are all done, and see what he has to say. I am not too thrilled with his tuning ability, but they are the only shop here in Portland that does it. I sent him the original log and haven't heard back at all.
Posted: Thu Sep 03, 2009 6:18 pm
by Cruisin1966
Looked at your file. Next time you log, select the "Default_DCX_07" dashboard from the drop down list. That should have the Accelerator Pedal Position PID.
Anyway, back to the task at hand. I still see a bit too much ST knk (for my liking) in the 4000-4800 and 5000-7000 range. Maybe you could try a 7/15/15 combination and see if that helps?
