Page 1 of 2
Gear change 2009 Challenger R/T
Posted: Mon Sep 07, 2009 10:11 pm
by Wicked09
I have your Predator #7135 for my Challenger R/T. I'm going to be changing out the 306 rear gear for the Richmond 355. According to what you say the Predator can do, I should be able to adjust that with the tuner correct?? If so, where do I find that in the tuner and is it pretty easy to do?? Or do I need to down load an update?? I was also wondering if you can confirm that the rear end in the 09 Challenger R/T is the 215mm that I've heard it is. Other wise the Richmond gears won't work. Thanks.
RE: Gear change 2009 Challenger R/T
Posted: Tue Sep 08, 2009 2:44 am
by Mike_Levy
The R/T has the 210mm rear end, and Richmond does make 210 gears. Only the SRTs have the 215.
Posted: Tue Sep 08, 2009 10:18 am
by Wicked09
Thank you. Now all I need is the answer on changing the gear ratio with the Predator.
Posted: Tue Sep 08, 2009 12:54 pm
Can do...
Posted: Tue Sep 08, 2009 12:59 pm
by Wicked09
OK...and how can I do that??
Re: RE: Gear change 2009 Challenger R/T
Posted: Tue Sep 08, 2009 1:25 pm
by BigTwin_Georg
mikel wrote:Can do...
I have SRT manual 2009 and I can't change my gear ratio too. My Predator is U7135 rev 9R18.
http://media7.dropshots.com/photos/2537 ... 185650.jpg
RE: Re: RE: Gear change 2009 Challenger R/T
Posted: Tue Sep 08, 2009 1:58 pm
It is under quick adjust/axle ratio
Re: RE: Re: RE: Gear change 2009 Challenger R/T
Posted: Wed Sep 09, 2009 2:11 pm
by BigTwin_Georg
mikel wrote:It is under quick adjust/axle ratio
I know where it is. I can't change my gear ratio.
RE: Re: RE: Re: RE: Gear change 2009 Challenger R/T
Posted: Wed Sep 09, 2009 2:13 pm
what is your calid, and what revision is on the Predator?
Re: RE: Re: RE: Re: RE: Gear change 2009 Challenger R/T
Posted: Mon Sep 14, 2009 10:00 am
by BigTwin_Georg
mikel wrote:what is your calid, and what revision is on the Predator?
Dodge Challenger STR8 2009 manual
callid 68004308AF (downgrade from 68004308AG)
U7135 rev 9r18
Thank you for your interest.
RE: Re: RE: Re: RE: Re: RE: Gear change 2009 Challenger R/T
Posted: Mon Sep 14, 2009 10:54 am
This should be fixed in the latest beta crom Johan has posted...
Re: RE: Re: RE: Re: RE: Re: RE: Gear change 2009 Challenger
Posted: Mon Sep 14, 2009 12:45 pm
by BigTwin_Georg
mikel wrote:This should be fixed in the latest beta crom Johan has posted...
That's not good news for me: I'm planning to run with hi-flo catalysators and therefore I will disable rear O2's. Is here another way? Maybe to get 9r17?
RE: Re: RE: Re: RE: Re: RE: Re: RE: Gear change 2009 Challen
Posted: Mon Sep 14, 2009 1:12 pm
If you have to use the latest revision, you will need a custom tune.
Posted: Tue Sep 22, 2009 6:56 pm
by renegade
I get the fail to change axle ratio also with the u1735 rev9r18 in my 09 r/t six speed. I would like to keep the egr off. If I export the tune I have now and save it as a custom tune, then get the new revison, will I be able to adjust axle ratio in my saved custom tune?
Posted: Wed Sep 23, 2009 9:56 am
Yes...
