I am getting the P0172/Po175 OBD code. I'm running the U7140 Steeda 91 Oct tune. I will reset the code, and it will be fine for two or three days. Today, when I "lit 'em up" the engine light (and codes) came back on. I've cleaned my MAF sensor already. Should a Dyno tune correct the common "running lean" / "running rich" codes?
Cal ID FBJR3G5
Any suggestions?
Scott
Resubmitting question
Mineral_GT
Mineral Grey 2005 Mustang GT 5Spd. Red Leather Int.
Steeda Lowering Springs
Steeda CAI
Steeda Axle Back Exhaust
BBk Throttle Body
UDP
GT500 Wheels
Steeda CAI
BBk Throttle Body
UDP
GT500 Wheels
RE: Resubmitting question
If you are getting lean codes, it sounds like you have the wrong tune installed.
Options>show last tune written, this should read Steeda tune.
If not, you need to install the correct tune.
