New install U-7134
ptgtrialto
New install U-7134
Post by ptgtrialto »
06 PT Cruiser GT Auto Stick
9R17 updated
Just installed 93 oct tune .... Runs Great ,but quite alot of pinging when accelerating hard
Any suggestions ????
Also can you make additional changes under modify after the 93 OCT TUNE has been installed ????
tuningss
RE: New install U-7134
Post by tuningss »
Remove some timing and add some fuel. Give that a shot and see how it responds.
http://www.tpctuning.com
what Mike said ^ ^ ^ ^ ^
ptgtrialto
Is this done on the modify tune mode on the hand held unit ????? if so how much timing to remove & how much fuel to add???
I am new @this .. so go simple on me ...Thanks
gizmodo
Post by gizmodo »
Yes, use the modify tune. I am going to assume you have a wideband. What do your AFRs look like? I would only change one thing at a time. If your AFRs look good, pull a degree or two of timing. If you are lean, add fuel and see how that goes.
Return to “General Support”
