Page 1 of 3
U7137 Out of Memory
Posted: Mon Oct 12, 2009 8:15 pm
by gw8816
I have a U7137. Installed 9R05 today, and tuned the truck with the 93 perf tune. Downloaded the original back-up to save. Now when trying to download the last tune written, i keep getting an "Out of Memory" message on the predator. I've tried it three times with the same results.
Anybody have any ideas on how to clear the memory?
RE: U7137 Out of Memory
Posted: Tue Oct 13, 2009 9:28 am
by Crimson
I havent had the chance to hook up mine to the computer yet. I have the predator updated to the 9R05. See if I have the chance today.
Posted: Tue Oct 13, 2009 9:46 am
by MGH
I got the same message yesterday. All you need to do is re-install the 93 tune again.
Posted: Wed Oct 14, 2009 10:35 pm
by 09Laramie
I just got my predator and I also got an "Out of Memory" error.
First plugged it in to my truck ('09 Ram 1500, 5.7L Hemi) and got a message saying that my vehicle needed an update. Did the DCX update, and at the end of the update, just after a bunch of key cycles, it gave me that "Out of Memory" error. Unplugged the predator when it prompted me to, turned the key off, and then I was able to download the original backup and write the 87 tune with no more errors.
Question for the Diablosport staff: Is this "Out of Memory" error something to be concerned about? Is it something that either needs to be fixed or will be fixed in a future crom release?
and a side question for anybody that knows the answer- what does DCX stand for, and what exactly does that do to the vehicle?
Posted: Thu Oct 15, 2009 12:03 am
by concoursd
daimler chrysler
Posted: Thu Oct 15, 2009 8:41 pm
by gw8816
I took the truck back to the original state. Re-installed 9R04, and installed 93 can tune. Hooked up to computer and backed up original and last tune written. Go back to 9R04, fixed the problem. I can only surmise that 9R05 has a bug. Atleast so much as retrieving the last file written. Hope this helps others experiencing this issue.
Posted: Fri Oct 16, 2009 8:57 am
I'll look into this...
Posted: Fri Oct 16, 2009 11:35 am
please post up a VIN and calid for those having this issue...
Posted: Sat Oct 17, 2009 10:06 pm
by 09Laramie
calid is 68059434AB (after the DCX update from a calid of 68059434AA), and PM sent with the VIN
Posted: Sun Oct 18, 2009 7:29 pm
by lross78550
Original Calid was 68059437AA
Current Calid is 68059437AB
VIN # PM'ed to mikel
Lee
Posted: Thu Oct 22, 2009 11:16 pm
by 09RamOhio
I had this issue as well. Can get the info tomorrow if you like.
It was during the initial Performace Tune step. The step took a good 10-15 minutes, had me turn the key off, back on, then off and back on, at which point it said out of memory. I then proceeded to put the 93 tune on, it backed up my stock and put the 93 on without error. I now have my stock tune on my PC
Posted: Tue Nov 03, 2009 8:59 am
by wes@tps
I'm having the same issue on 56029161AF. Attempting to datalog via PC immediately shows "Out of Memory" on the tool.
2004 5.7L Truck
Wes
Re: RE: U7137 Out of Memory
Posted: Thu Nov 12, 2009 2:19 pm
by ironbyron
Mine shows out of memeroy also
U7137x
2009 Dodge Hemi Ram
Calid 68059431AB
Vin have emailed mike
Posted: Fri Nov 13, 2009 10:58 am
by butch1581
Same Issue:
Calibration ID
PCM: 56029207AK
TCM: 56029224AF
VIN: 1D7HU18276S625419
Posted: Fri Nov 13, 2009 11:12 am
by butch1581
gw8816 wrote:I took the truck back to the original state. Re-installed 9R04, and installed 93 can tune. Hooked up to computer and backed up original and last tune written. Go back to 9R04, fixed the problem. I can only surmise that 9R05 has a bug. Atleast so much as retrieving the last file written. Hope this helps others experiencing this issue.
Where can I get 9R04?
