Well we have been playing around here with some 5.7L's and so far so good.
We are seeing an 20hp and 20ft/lbs gain across the board on these motors, which is substantial on a gasoline vehicle.
Here is pic and dyno sheet.
5.7L update
5.7L update
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
Great news!! I am anxiously awaiting a tuner from Diablosport for my 05 1500 Hemi, right now I have superchips
but I really need something to tune my aftermarket cam with. I would be happy to be a beta tester if you guys ever need one.
2005 Dodge 1500 Hemi QC 4x4
Current tuner: Superchips
Mods: PPP(Power Ported Performance) Road Warrior Camshaft, AT3030, Airram Jetstream
Question about functionality - MDS
REPOST: from another area because it didn't seem to get an answer
The 07 and a few prior years of Dodge Truck Hemi's have an Multi-Displacement System (MDS).
Click on that MDS and you'll see a dodge animation of what I'm talking about directly off Dodge's web site.
Basically the system deactivates four cylinders during optimal driving conditions making the V8 into a fuel saving V4 during highway cruising and then when power again is needed, such as for passing or when you step down futher on the gas, the other 4 cylinders kick back into action giving you that desired V8 horse power.
I'm really curious to see how the Predator is going to react/treat that system. Quite a few programmers out there completely deactivate that system.
OMG I'm shocked they would disable such a great factory money saving feature! I'm hoping that Predator will somehow be able to provide a tune that takes advantage of that system as well, without de-activating it.
Do you have any ideas what the plan is for that or will the predator's tuning disable that money saving feature like all the other brands of programmers seem to do?
Also, my truck has 3 options concerning it's overdrive performance settings that are available directly off my shift lever (ya it's an automatic). (I believe this is a standard feature on all 07 Dodge Trucks.)
I was wondering if the Predator will affect those, or will it replace those with more optimal settings? Or will it just disable those?
I know it's probably expensive for a company to create programmers for specifics such as this. But I'm hoping that features like these don't go to the waste site in the persuit of just getting a programmer to market. We all love to get the max out of our engine, we all also love to keep some of it's gas and money saving features on a day to day basis.
Oh and one more simple feature to add to the programmer would be disabling the constant annoying pinging if the driver or passenger forgets/elects not to buckle their seat belts. I know it's controlled by the computer as the manual dictates a manual way to disable this.
For those who want to know how to do this manually it's quite simple.
1) Get into vehicle, buckle your seat belt. Ignition must be off.
2) Insert key into ignition and turn to "on" (it is not necessary to actually start the vehicle)
3) Wait for the dashboard seatbelt light to turn off.
4) Immediately unbuckle and rebuckle your seat belt three times
5) With your seat belt still buckled turn off the ignition, you should hear a tone almost immediately - this is a confirmation tone of the feature reprogram.
NOTE: All this must be done within the first 60 seconds of turning the ignition to the "On" posistion
You're done. The light on the dash will always be there, but the tones are now gone. To re-enable simply repeat the instructions again.
I know buckling your seat belt is a good thing and required by law, but there are just times that the annoying tone could justifiably be turned off. For example a heavy package in the passenger seat on some of these vehicles means you'll have to literally buckle it in.
Thanks for your time, sorry if the questions seem moronic.
Dan
BTW: These seat belt warning tone feature disabling steps is true for most 05 or newer vehicles not just Dodge's.
Jeep, Chevy, Dodge, GM and the newer Fords all support this as well.
Did you also know that you can disable or re-enable the auto down feature of your electric windows switch.
There's instructions in your manual on how to do it. When I get home tonight I'll post those instructions as well.
- Basically, if I push the button once on the end of the shift lever then my over drive is disabled until I press it again.
- If I press it once more then the overdrive is re-enabled but the vehicle is in towing mode which is more suited for towing/hauling giving me more torque for when I need it, I believe in this mode the MDS is also de-activated.
- If I press it the third time I'm back to factory daily default driving with both the over drive and MDS enabled.
Dan
PowerBBS
07 Dodge Ram 1500 5.7 4x4 Quad Cab Big Horn Ed
S&B Cold Air Ram Intake w/TBody Spacer
NGK Performance Plugs
Max Flow Exhaust
Tested:
Hyperpac Beta
HyperTech Max Energy
SuperChips FlashPaq
BullyDog Triple Dog
Jet Chips PCM Stage II
Max Flow Exhaust
Tested:
Hyperpac Beta
SuperChips FlashPaq
BullyDog Triple Dog
RE: Question about functionality - MDS
In reference to the MDS, Johan would have to describe the specifics, but it is similar to the DOD (displacement on demand) system currently used by GM in cars and trucks.
Thus far our experiences with that system so far have been interesting.
On the LS4 front wheel drive cars (Impala SS, Monte Carlo SS) we offer the user the option of the tune with or without the DOD enabled.
So far, overwhelming response has shown the non DOD tune to be the favorite, and they generally report up to 2 mpg gains over the stock tune with DOD engaged. It would seem that the benefits of a proper tune outweigh even these whiz-bang features from the OEMs...
We recently sent out a few tunes to some 07 GM truck owners to disable the DOD system, as the default tunes for those trucks leave it enabled. I do not knoow if we have heard back from them as of yet.
So for now, it is still too early to say for sure if this will be available in the Predator or not, but we will experiment with it.
As for your question about the shift modes, again this would appear similar to the GM tow/haul mode system, but again it is too early to say how these systems will work.
I will say that none of them will be disabled, so do not worry about that.
I don't think we're gonna get into the seatbelt thing unless there is a simple switch in the programming that can easily be turned off, but thanks for posting that info.
He he, just tried that disable seat belt feature and it works, love it.
We will not disable MDS, we might have an adjustable parameter to disable it if deemed necessary.
The tow/haul, od/off settings will not be altered either, we will not be doing tcm support initially so shift settings will remain stock aside from the torque management controlled by the pcm.
Diablosport INC
Diablosport INC
Re: RE: Question about functionality - MDS
What about shift points? I don't know whether that is TCM or PCM, so is that a shift setting or are you referring just to line pressure, shift time, and stuff like that?johan wrote:He he, just tried that disable seat belt feature and it works, love it.
