GT500 PID List
General Trinity Support
JimL
GT500 PID List
Post by JimL »
Is there a list of PID for mustang GT500? The list on the web site only has ford diesel pid's
Also could fuel injector duty cycle and boost pressure be viewed or data-logged?
RE: GT500 PID List
I'll see what I can find for a PID list.
Duty cycle and boost can be viewed and logged.
JimL
Re: RE: GT500 PID List
Post by JimL »
mikel wrote:I'll see what I can find for a PID list.
Thank you
If possible could you tell me where to find those 2 parameters? I have the trinity hooked up but could not find them.
Also is there any way to view TPS voltage and if so where could I find that one too?
Thank you again
RE: Re: RE: GT500 PID List
You'd find those PIDS under the synthesized PID list.
jimb
Post by jimb »
IF your referring to Injector Pulse width duty cycle - Synthesized PID; It's only available for SRT-4. Synthesized Boost is available if Trinity can acquire MAP and BARO PIDs.
JimL
Re: RE: Re: RE: GT500 PID List
Post by JimL »
jimb wrote:IF your referring to Injector Pulse width duty cycle - Synthesized PID; It's only available for SRT-4. Synthesized Boost is available if Trinity can acquire MAP and BARO PIDs.
Things I would love to see added to the trinity to log/view for GT500 5.4
TPS voltage ETC(tps 1)
ETC(TPS2
Boost
Injector duty cycle.
How often to you guys add parameters to view to the tool?
Will you be adding any other parameters to view/log to the trinity for this vehicle?
thank you
kmac1
RE: Re: RE: Re: RE: GT500 PID List
Post by kmac1 »
Some of the parameters you have requested are DMR's and not PID's. DMR's are not in the tool at this time. This is a very good request though. I'll have to discuss with my boss if it would be possible to add them into a future revision. A boost gauge in Trinity would look pretty cool. On another note, if you have a laptop and our Dataviewer you can see all of the above parameters but boost will need to be converted to psi if that is how you like to see it. Duty cycle will need to be calculated off of RPM and Injector PW. A little more time consuming but definitely some valuable data if you are custom tuning the car.
Kev
Kevin MacDonald
Calibration
www.jpcracing.com
For DiabloSport Tech Support: [email protected]
Return to “General Trinity”
