boost gauge on a trinity
General Trinity Support
soccerjunky
Post by soccerjunky »
can u use the trinity to monitor boost on a supercharged challenger?
RE: boost gauge on a trinity
Monitor the MAP.
Yes, there is a synthesized PID called boost which is MAP-baro, to give actual boost pressure.
delux
Post by delux »
I just purchased a trinity for my SRT4 but the synthesized boost PID always stays at zero when I'm monitoring it. Do I need to do something else to configure it? My car is completely stock but I've flashed the 93perf tune.
gizmodo
Post by gizmodo »
No, you shouldn't need to do anything for it to work. Do values in the other gauges change?
PaCharger_
Post by PaCharger_ »
doesnt work for me either. shows zero's then even when i'm not in boost it'll jump to 40 psi, etc.....
I'm guessing it's another LX v07 bug...
jimb
Post by jimb »
Please create a Trinity log monitoring RPM, MAP, BARO and Synth Boost. Export them from Trinity using DataViewer and post here.
delux
Post by delux »
Oops... It appears to be working, for some reason i was expecting it show negative values when i was in vacuum :P. Thanks though.
GeeTeePT
Post by GeeTeePT »
Will this also show the boost for my PT Turbo ? Which gauge is the monitor for boost? Can you help me set this up ? New to all this and have a zillion obvious questions.
gizmodo
Post by gizmodo »
Yes, it will work just fine. There is nothing to setup, just create a gauge layout and go to synthesized pids and select boost.
Return to “General Trinity”
