boost gauge on a trinity
Posted: Mon Jan 04, 2010 10:03 pm
by soccerjunky
can u use the trinity to monitor boost on a supercharged challenger?
RE: boost gauge on a trinity
Posted: Tue Jan 05, 2010 3:35 am
by Mike_Levy
Monitor the MAP.
Posted: Tue Jan 05, 2010 10:42 am
Yes, there is a synthesized PID called boost which is MAP-baro, to give actual boost pressure.
Posted: Fri Mar 12, 2010 2:45 am
by delux
I just purchased a trinity for my SRT4 but the synthesized boost PID always stays at zero when I'm monitoring it. Do I need to do something else to configure it? My car is completely stock but I've flashed the 93perf tune.
Posted: Fri Mar 12, 2010 10:10 am
by gizmodo
No, you shouldn't need to do anything for it to work. Do values in the other gauges change?
Posted: Fri Mar 12, 2010 10:54 am
by PaCharger_
doesnt work for me either. shows zero's then even when i'm not in boost it'll jump to 40 psi, etc.....
I'm guessing it's another LX v07 bug...
Posted: Fri Mar 12, 2010 11:06 am
by jimb
Please create a Trinity log monitoring RPM, MAP, BARO and Synth Boost. Export them from Trinity using DataViewer and post here.
Posted: Fri Mar 12, 2010 10:16 pm
by delux
Oops... It appears to be working, for some reason i was expecting it show negative values when i was in vacuum
. Thanks though.
Posted: Tue Jul 06, 2010 12:19 am
by GeeTeePT
Will this also show the boost for my PT Turbo ? Which gauge is the monitor for boost? Can you help me set this up ? New to all this and have a zillion obvious questions.
Posted: Tue Jul 06, 2010 8:38 am
by gizmodo
Yes, it will work just fine. There is nothing to setup, just create a gauge layout and go to synthesized pids and select boost.
