my truck still wont break 100!!
black'doutchevy09
Post by black'doutchevy09 »
i tried turnin my speed sensor off so i could go faster than 100 but it still wont do it now im wonderin if i even did it right. what setting do i go to to turn it off?
RE: my truck still wont break 100!!
ummm... what year/make/model truck??
what predator??
what revision is it on?? when it boots up to the main menu, there's a number at the top of the screen... that's the revision number... what is it?
black'doutchevy09
i got a 09 silverado with the 5.3.. i got the preditar v.9r13 and the revision number is u7194... i went to options then speed limiter and then turned it off and tuned it after was that the right option?
neonhomer
Post by neonhomer »
I am not sure about the 09s, but mine had two options... ETC and non ETC..... make sure both are set to end of range
NeonHomer
1996 Jeep Grand Cherokee I6 4.0
steeleshark2
Post by steeleshark2 »
black'doutchevy09 wrote:i got a 09 silverado with the 5.3.. i got the preditar v.9r13 and the revision number is u7194... i went to options then speed limiter and then turned it off and tuned it after was that the right option?
Did you actually load the tune after you made the changes in the Predator?
2010 Camaro SS
Transformers Edition
DIABLEW PREDATOR TUNED
Muffler Delete
Volant CAI
black'doutchevy09
haha ya after i set the tune it asked would you like to tune now and i put yes but still nothin... does it take a while to load or anything?
black'doutchevy09
09 silverado 5.3 flowmaster cat back
-diablosport predator u7194 - 9r13
tdub09
Post by tdub09 »
no should be right away for the no limit to take affect!! your trims and stuff takes bout 35 miles or few more to settle n... try loading your stock tune back then try putting the diablo tune back in with the settings you want
2009 GMC
to much to list
U7194 DIABLEW TUNED
"THERES NO REPLACEMENT FOR DISPLACEMENT"
black'doutchevy09
i tried again it still wont work... i tuned it back stock then tuned it again back to the diablo tune and tuned all my custom settings and it still wont work..... you select the speed limiter option then turn speed limiter off right?? or was that not the right way?
black'doutchevy09
steeleshark2
You can go with a custom tune with Monte. Get a custom tune and you will get everything you can out of the truck as well as the speed limiter should be fixed..
2010 Camaro SS
Muffler Delete
Volant CAI
black'doutchevy09
how?
black'doutchevy09
email sent...
couldn't send you a PM, because you used that apostrophe in your username, so the system doesn't find your name when it tries to send you a PM...
heh...
chebbyfan
Post by chebbyfan »
Not trying to hijack this thread, but what is "ETC and non ETC" ? I had three settings for my speed limiter, but just went to the last one and completely shut it off. Isn't that good or do I need to set those other two out at their limits? P.S. Mine is same predator and the only difference is my silverado is an 08.
Electronic Throttle Control...
i.e. drive-by-wire...
and non-etc means you have an actual throttle cable, not drive-by-wire electronic throttle...
you can set/disable all 3 speed limiter settings...
black'doutchevy09
see mine is an 09 silverado and my predator says speed limiter and you select that and it say on or off and i selected off but still no difference you got any ideas monte??
black'doutchevy09
nope...
only thing I can think of is... after you used the arrows to highlight the "OFF" selection, did you then press the center button on the predator to actually make/save the highlighted choice???
and then after that you need to press the ESC button a few times until it asks you "Install tune now?" and then you select YES and it installs your changes....
also, when you went in to "Modify Tune" - you selected the same diablo tune that you installed before, right?
