my truck still wont break 100!!
Posted: Sun Jan 24, 2010 5:27 pm
by black'doutchevy09
i tried turnin my speed sensor off so i could go faster than 100 but it still wont do it now im wonderin if i even did it right. what setting do i go to to turn it off?
RE: my truck still wont break 100!!
Posted: Sun Jan 24, 2010 5:44 pm
by 06MonteSS
ummm... what year/make/model truck??
what predator??
what revision is it on?? when it boots up to the main menu, there's a number at the top of the screen... that's the revision number... what is it?
Posted: Sun Jan 24, 2010 8:23 pm
i got a 09 silverado with the 5.3.. i got the preditar v.9r13 and the revision number is u7194... i went to options then speed limiter and then turned it off and tuned it after was that the right option?
Posted: Sun Jan 24, 2010 10:09 pm
by neonhomer
I am not sure about the 09s, but mine had two options... ETC and non ETC..... make sure both are set to end of range
Posted: Sun Jan 24, 2010 10:31 pm
by steeleshark2
black'doutchevy09 wrote:i got a 09 silverado with the 5.3.. i got the preditar v.9r13 and the revision number is u7194... i went to options then speed limiter and then turned it off and tuned it after was that the right option?
Did you actually load the tune after you made the changes in the Predator?
Posted: Sun Jan 24, 2010 10:32 pm
haha ya after i set the tune it asked would you like to tune now and i put yes but still nothin... does it take a while to load or anything?
Posted: Sun Jan 24, 2010 11:23 pm
by tdub09
no should be right away for the no limit to take affect!! your trims and stuff takes bout 35 miles or few more to settle n... try loading your stock tune back then try putting the diablo tune back in with the settings you want
Posted: Mon Jan 25, 2010 4:28 pm
i tried again it still wont work... i tuned it back stock then tuned it again back to the diablo tune and tuned all my custom settings and it still wont work..... you select the speed limiter option then turn speed limiter off right?? or was that not the right way?
Posted: Mon Jan 25, 2010 5:05 pm
by steeleshark2
You can go with a custom tune with Monte. Get a custom tune and you will get everything you can out of the truck as well as the speed limiter should be fixed..
Posted: Wed Jan 27, 2010 5:05 pm
how?
Posted: Wed Jan 27, 2010 5:24 pm
by 06MonteSS
email sent...
couldn't send you a PM, because you used that apostrophe in your username, so the system doesn't find your name when it tries to send you a PM...
heh...
Posted: Thu Jan 28, 2010 8:47 am
by chebbyfan
Not trying to hijack this thread, but what is "ETC and non ETC" ? I had three settings for my speed limiter, but just went to the last one and completely shut it off. Isn't that good or do I need to set those other two out at their limits? P.S. Mine is same predator and the only difference is my silverado is an 08.
Posted: Thu Jan 28, 2010 10:13 am
by 06MonteSS
Electronic Throttle Control...
i.e. drive-by-wire...
and non-etc means you have an actual throttle cable, not drive-by-wire electronic throttle...
you can set/disable all 3 speed limiter settings...
Posted: Thu Jan 28, 2010 3:26 pm
see mine is an 09 silverado and my predator says speed limiter and you select that and it say on or off and i selected off but still no difference you got any ideas monte??
Posted: Thu Jan 28, 2010 5:06 pm
by 06MonteSS
nope...
only thing I can think of is... after you used the arrows to highlight the "OFF" selection, did you then press the center button on the predator to actually make/save the highlighted choice???
and then after that you need to press the ESC button a few times until it asks you "Install tune now?" and then you select YES and it installs your changes....
also, when you went in to "Modify Tune" - you selected the same diablo tune that you installed before, right?
