Calculating tire size
http://www.gordon-glasgow.org/tirecalc.html
or, use this handy tire revs per mile calculator:
Tire_Conversion_Revs.xls
(25 KiB) Downloaded 1531 times
charala
RE: Calculating tire size
Post by charala »
I run staggered tire sizes; I assume I should use the tire size info from my rear tires for this calculation...am I correct? :punisher:
Thanks,
-Chris
tuningss
Post by tuningss »
Yes, the rear tires are the ones you use.
http://www.tpctuning.com
Gointopless
Post by Gointopless »
There are all kinds of apps for smart phones too..
bugattis4
Post by bugattis4 »
thank you!!!
SFDBR14
Post by SFDBR14 »
These calculations will get you in the ballpark. However, it has been my experience that your speedometer will be off by about 5 mph @ 80mph. I used my GPS to help me fine tune the value for the revs per mile in the tune. I ended up having to use a value of 880 revs per mile for a set of 275/40 R18 wheels. If you run this through your calculations it will tell you that you should be running 756 for the revs per mile.
2012f1503.7
Re: Calculating tire size
Post by 2012f1503.7 »
I'm trying to do the tire Change on my truck and was wondering do I put in the revs per mile in the tire circumference? I'm running a 35x12.50x20.
isato01
Post by isato01 »
sup bruh ,im tried to recalibrate my speedo but it asked for diameter and mine says is 100.25 for a set of 275/55/20 lowest value is 500 what im doing wrong :normal:
Return to “Trinity Ford Gas”
