U7135 O2 sensor
PhilCartier
U7135 O2 sensor
Post by PhilCartier »
Hi,
I'm new on your forum and i have a question for you guys... (First pardon my poor english i'm a french canadian...). I have a U7135 Predator and i would like to know why i don't have the option for disable the O2 sensor (rear). I download the latest version V9r22 and i don't see anything about O2 sensor in the parameter change menu... Is it because a have a 2006 Dodge Charger SRT-8? Is the 2006 don't have this option?
I just install Magnaflow high flow cats and i see the check light with code P420 and P430... I know i can install "spark plug non-fooler" on the O2 sensor but on other forum some guys said we can disable the downstream O2 sensor with the Predator???
I will wait for your answer,
Phil :?:
RE: U7135 O2 sensor
You cannot legally disable the sensors in the US, so they no longer give the option. I don't know the Canadian laws, so I'm not sure if you can disable them or not. A dealer with the CMR software can do it for you if necessary.
Its really better to do it with the non-foulers. As least they have a chance at passing any inspection you may have. With the sensors disabled, you automatically fail.
PhilCartier
Re: RE: U7135 O2 sensor
Mike_Levy wrote:You cannot legally disable the sensors in the US, so they no longer give the option. I don't know the Canadian laws, so I'm not sure if you can disable them or not. A dealer with the CMR software can do it for you if necessary.
Thanks for the information!
Phil
PhilCartier
Is it possible to buy or to get somewhere the option "rear O2 sensor disable" in the Predator parameters and download it instead of installing non-fouler?
BigTwin_Georg
Post by BigTwin_Georg »
PhilCartier wrote:Is it possible to buy or to get somewhere the option "rear O2 sensor disable" in the Predator parameters and download it instead of installing non-fouler?
If you have 06 Charger SRT then you can run crom 9r17 (and lower), there is still option "rear o2 dissable".
PhilCartier
Is the 93 oct.+CAI got the same performance with the old version (crom 9r17) then the newest version? If it's the same you make my day. Just a thing... On the download page of DiabloSport the only old version we can download is the crom 9r12...Is it still ok to download this version (for performance of the 93 oct.+cai tune)?
Thanks,
