06MonteSS original and current tune as requested
highvortex
Post by highvortex »
Hey Monte, here are the two files you said you needed.
Original Back up.grg
(62.92 KiB) Downloaded 151 times
custom_tune.grg
(3.25 KiB) Downloaded 143 times
here ya go man...
now, you'll need to save that custom tune file to your PC and load that custom tune into your predator, so...
Importing a custom tune into the Predator:
1. Open up the DSDownloader and connect the Predator to the PC and power it up.
2. Let the DSDownloader auto connect to the tool.
3. On the DSDownloader press the "send tune file to Predator" button.
4. You will get a new window asking you to select the file for importing.
5. Browse through your PC to find where you saved the custom tune file, and click it once, then click "open".
6. If this is the first time you are sending a tune to the Predator, you will get a new window saying "a valid base file could not be found". So you need to click "Yes". (The "base file" is the copy of your original backup stock tune.)
7. Now, browse your folders or desktop to look for the copy of your "original backup" stock tune file you saved before, and highlight it - then click "open".
8. The DSDownloader will automatically compare these files to determine if they are the same size and of the same calibration.
9. Once it determines the files are OK, it will import the custom tune file to the Predator. This will all happen very fast, usually in under 10 seconds.
10. The DSDownloader will tell you that the import was successful, and the Predator screen will show/flash "import OK".
11. You may now unhook the Predator and go to the vehicle to install the custom tune.
READ "** IMPORTANT NOTE" BELOW BEFORE INSTALLING TO YOUR VEHICLE!
** IMPORTANT NOTE: your predator may prompt you to say that you are changing tunes, and then ask you if you want to "Reset All Parameters?" - make sure you answer/select YES to this question to reset the parameters that you adjusted before. The changes you made yourself before are already in the custom tune, since you copied it out of your car to send to the tuner. If you select NO, then it will apply your adjustments on top of the adjustments that are already in the tune, and it will get ugly.
You can also still modify the custom tune just like any of the performance tunes.
Do the install just like any other performance tune, and you're good to go with your new custom tune.
Highvortex_NoCATs_NoO2s.grg
(54.42 KiB) Downloaded 141 times
Return to “Trinity GM Gas”
