Page 1 of 2
Logging Parameters locations in sub-menus - by aviraled2002
Posted: Mon Mar 01, 2010 2:19 pm
by 06MonteSS
Thanks for the mapping aviraled2002!!!
In the Trinity and new revision 7194 Predators, the logging/monitoring parameter listings are now all under different sub-menus.
This guide below can be used to locate the necessary parameters needed to log for a custom tune...
Air Fuel Ratio (Equivalence Ratio) = Under FUEL menu
Long Term fuel trim bank 1 = under FUEL menu
Long Term Fuel Trim Bank 2 = under FUEL menu
Spark Advance = under IGNITION menu
Intake air Temp = under INTAKE menu
MAF Sensor Mass Air Flow = under INTAKE menu
Total Knock Spark Retard =under MISFIRE menu
Engine Speed (RPM) = under PERFORMANCE menu
Commanded Throttle position (or Absolute Throttle Position - for older vehicles that don't have the Commanded parameter) = under THROTTLE menu
RE: Logging Parameters locations in sub-menus - by aviraled2
Posted: Mon Mar 01, 2010 3:49 pm
The dslog_redux layout should still work fine though....
Posted: Mon Mar 01, 2010 4:14 pm
by 06MonteSS
yes... but it is missing 1 of them I think...
cuz I remember having to add one to the preset layout...
Posted: Mon Mar 01, 2010 5:16 pm
tell me which one so I can add it in next update...
Posted: Mon Mar 01, 2010 5:41 pm
by 06MonteSS
k... I'll have to check...
if I still have that default layout lol...
just look through your gauge layout, and see if you have all of these in it:
Spark Advance
Intake air Temp
Engine Speed (RPM)
Commanded Throttle Position
Absolute Throttle Position -- need to add this one in, cuz older vehicles won't have the Commanded Throttle parameter (this was not the one I added tho... but I just thought of this one to add)
Re: Logging Parameters locations in sub-menus - by aviraled2
Posted: Sun Jul 11, 2010 1:24 pm
by srt8-in-largo
My Trinity doesn't have an ignition, intake, misfire, or performance menu. Each of those PIDs is in yet a different folder.
Trying to track PIDs by folder is impossible. Its like a shell game.
RE: Re: Logging Parameters locations in sub-menus - by avira
Posted: Sun Jul 11, 2010 2:15 pm
by 06MonteSS
that's because you do not have a GM vehicle... you have a dodge/chrysler.... your stuff is totally different than GM's...
that's why this info is in the Trinity
GM forum....
you can't use the GM tuning info to try and do things on your dodge/chrysler vehicle... your stuff is all different...
Posted: Sun Aug 26, 2012 12:50 pm
by 1QWIK7
I spent 30 minutes trying to find the tire size option and I couldn't find it.
Even uploaded the Diablo tune to my car thinking maybe the tire size option will show up. Nothing..
I checked every single parameter. Check the options menu etc
Is it not available? This is for a 2006 gto m6 btw.
Posted: Sun Aug 26, 2012 2:20 pm
by 06MonteSS
no, there is no tire size option for that vehicle... you would need to get a custom tune done in order to have it changed in the tune file...
Posted: Wed May 08, 2013 2:17 pm
by dwolson2
2001 Chevy Silverado, trying to find AFR, My options in fuel menu are:
Short term Fuel, Trim Bank 1
Long Term Fuel, bank 1
Short term Fuel, Trim Bank 2
Long Term Fuel, bank 2
Fuel tank Vapor, Pressure A/D
Fuel Level Sensor, A/D
Fuel Trim Cell
Fuel Tank Rated, Capacity
Total Fuel Volume
Fuel Level Sensor A/D, Second Tank
Fuel level, Output counter
Posted: Wed May 08, 2013 3:08 pm
by Ill_Born_SS
Have you tried to view using dataviewer live thru your device. At the top in dataviewer find and select infrequently used PIDs and then re-populate the list. Some computers have the required PIDS for dlredux
Posted: Wed May 08, 2013 5:28 pm
by dwolson2
Ill_Born_SS wrote:Commanded Throttle position (or Absolute Throttle Position - for older vehicles that don't have the Commanded parameter) = under THROTTLE menu
AFR isn't in my fuel menu, which is why I posted the entire menu and what my choices are
I have yet to try the dataviewer live, I can try it tomorrow.
Posted: Thu May 09, 2013 12:59 am
by 06MonteSS
you won't have the AFR/Equivalence Ratio parameter available for your old truck...
Posted: Thu May 09, 2013 3:20 pm
by dwolson2
06MonteSS wrote:you won't have the AFR/Equivalence Ratio parameter available for your old truck...
Your killing me
I was reading yout post on adjusting injector slope(
http://diablosport.com/forum/viewtopic. ... &start=135) and was trying to get it dialed in. Oh well. I'm going to have to install it on my newer dodge so I can play more
Posted: Sun May 12, 2013 8:53 pm
by 1QWIK7
Does anyone if there is, or soon have an update for the GM gas trinity??
I checked the main site but I only see updates for other stuff, not GM gas.
