Logging Parameters locations in sub-menus - by aviraled2002
Thanks for the mapping aviraled2002!!!
In the Trinity and new revision 7194 Predators, the logging/monitoring parameter listings are now all under different sub-menus.
This guide below can be used to locate the necessary parameters needed to log for a custom tune...
Air Fuel Ratio (Equivalence Ratio) = Under FUEL menu
Long Term fuel trim bank 1 = under FUEL menu
Long Term Fuel Trim Bank 2 = under FUEL menu
Spark Advance = under IGNITION menu
Intake air Temp = under INTAKE menu
MAF Sensor Mass Air Flow = under INTAKE menu
Total Knock Spark Retard =under MISFIRE menu
Engine Speed (RPM) = under PERFORMANCE menu
Commanded Throttle position (or Absolute Throttle Position - for older vehicles that don't have the Commanded parameter) = under THROTTLE menu
RE: Logging Parameters locations in sub-menus - by aviraled2
The dslog_redux layout should still work fine though....
yes... but it is missing 1 of them I think... ;)
cuz I remember having to add one to the preset layout...
tell me which one so I can add it in next update...
k... I'll have to check...
if I still have that default layout lol...
just look through your gauge layout, and see if you have all of these in it:
Spark Advance
Intake air Temp
Engine Speed (RPM)
Commanded Throttle Position
Absolute Throttle Position -- need to add this one in, cuz older vehicles won't have the Commanded Throttle parameter (this was not the one I added tho... but I just thought of this one to add)
srt8-in-largo
Re: Logging Parameters locations in sub-menus - by aviraled2
Post by srt8-in-largo »
My Trinity doesn't have an ignition, intake, misfire, or performance menu. Each of those PIDs is in yet a different folder.
Trying to track PIDs by folder is impossible. Its like a shell game.
RE: Re: Logging Parameters locations in sub-menus - by avira
that's because you do not have a GM vehicle... you have a dodge/chrysler.... your stuff is totally different than GM's...
that's why this info is in the Trinity GM forum.... ;)
you can't use the GM tuning info to try and do things on your dodge/chrysler vehicle... your stuff is all different...
1QWIK7
Post by 1QWIK7 »
I spent 30 minutes trying to find the tire size option and I couldn't find it.
Even uploaded the Diablo tune to my car thinking maybe the tire size option will show up. Nothing..
I checked every single parameter. Check the options menu etc
Is it not available? This is for a 2006 gto m6 btw.
no, there is no tire size option for that vehicle... you would need to get a custom tune done in order to have it changed in the tune file...
dwolson2
Post by dwolson2 »
2001 Chevy Silverado, trying to find AFR, My options in fuel menu are:
Short term Fuel, Trim Bank 1
Long Term Fuel, bank 1
Short term Fuel, Trim Bank 2
Long Term Fuel, bank 2
Fuel tank Vapor, Pressure A/D
Fuel Level Sensor, A/D
Fuel Trim Cell
Fuel Tank Rated, Capacity
Total Fuel Volume
Fuel Level Sensor A/D, Second Tank
Fuel level, Output counter
2012 Durango and 2001 Silverado
Ill_Born_SS
Post by Ill_Born_SS »
Have you tried to view using dataviewer live thru your device. At the top in dataviewer find and select infrequently used PIDs and then re-populate the list. Some computers have the required PIDS for dlredux
" Just Friggin Wicked"
Now with TCM support...
dwolson2
Post by dwolson2 »
Ill_Born_SS wrote:Commanded Throttle position (or Absolute Throttle Position - for older vehicles that don't have the Commanded parameter) = under THROTTLE menu
AFR isn't in my fuel menu, which is why I posted the entire menu and what my choices are
Ill_Born_SS wrote: Have you tried to view using dataviewer live thru your device. At the top in dataviewer find and select infrequently used PIDs and then re-populate the list. Some computers have the required PIDS for dlredux
I have yet to try the dataviewer live, I can try it tomorrow.
you won't have the AFR/Equivalence Ratio parameter available for your old truck...
dwolson2
Post by dwolson2 »
06MonteSS wrote:you won't have the AFR/Equivalence Ratio parameter available for your old truck...
Your killing me :lol: I was reading yout post on adjusting injector slope(http://diablosport.com/forum/viewtopic. ... &start=135) and was trying to get it dialed in. Oh well. I'm going to have to install it on my newer dodge so I can play more :)
1QWIK7
Post by 1QWIK7 »
Does anyone if there is, or soon have an update for the GM gas trinity??
I checked the main site but I only see updates for other stuff, not GM gas.
Return to “Trinity GM Gas”
