Logging Parameters locations in sub-menus - by aviraled2002
Thanks for the mapping aviraled2002!!!
In the Trinity and new revision 7194 Predators, the logging/monitoring parameter listings are now all under different sub-menus.
This guide below can be used to locate the necessary parameters needed to log for a custom tune...
Air Fuel Ratio (Equivalence Ratio) = Under FUEL menu
Long Term fuel trim bank 1 = under FUEL menu
Long Term Fuel Trim Bank 2 = under FUEL menu
Spark Advance = under IGNITION menu
Intake air Temp = under INTAKE menu
MAF Sensor Mass Air Flow = under INTAKE menu
Total Knock Spark Retard =under MISFIRE menu
Engine Speed (RPM) = under PERFORMANCE menu
Commanded Throttle position (or Absolute Throttle Position - for older vehicles that don't have the Commanded parameter) = under THROTTLE menu
RE: Logging Parameters locations in sub-menus - by aviraled2
The dslog_redux layout should still work fine though....
yes... but it is missing 1 of them I think...
cuz I remember having to add one to the preset layout...
tell me which one so I can add it in next update...
k... I'll have to check...
if I still have that default layout lol...
just look through your gauge layout, and see if you have all of these in it:
Spark Advance
Intake air Temp
Engine Speed (RPM)
Commanded Throttle Position
Absolute Throttle Position -- need to add this one in, cuz older vehicles won't have the Commanded Throttle parameter (this was not the one I added tho... but I just thought of this one to add)
Spark Advance
Intake air Temp
Engine Speed (RPM)
srt8-in-largo
Re: Logging Parameters locations in sub-menus - by aviraled2
My Trinity doesn't have an ignition, intake, misfire, or performance menu. Each of those PIDs is in yet a different folder.
Trying to track PIDs by folder is impossible. Its like a shell game.
RE: Re: Logging Parameters locations in sub-menus - by avira
that's because you do not have a GM vehicle... you have a dodge/chrysler.... your stuff is totally different than GM's...
that's why this info is in the Trinity GM forum....
you can't use the GM tuning info to try and do things on your dodge/chrysler vehicle... your stuff is all different...
I spent 30 minutes trying to find the tire size option and I couldn't find it.
Even uploaded the Diablo tune to my car thinking maybe the tire size option will show up. Nothing..
I checked every single parameter. Check the options menu etc
Is it not available? This is for a 2006 gto m6 btw.
no, there is no tire size option for that vehicle... you would need to get a custom tune done in order to have it changed in the tune file...
2001 Chevy Silverado, trying to find AFR, My options in fuel menu are:
Short term Fuel, Trim Bank 1
Long Term Fuel, bank 1
Short term Fuel, Trim Bank 2
Long Term Fuel, bank 2
Fuel tank Vapor, Pressure A/D
Fuel Level Sensor, A/D
Fuel Trim Cell
Fuel Tank Rated, Capacity
Total Fuel Volume
Fuel Level Sensor A/D, Second Tank
Fuel level, Output counter
Fuel Trim Cell
Total Fuel Volume
2012 Durango and 2001 Silverado
- Ill_Born_SS
Have you tried to view using dataviewer live thru your device. At the top in dataviewer find and select infrequently used PIDs and then re-populate the list. Some computers have the required PIDS for dlredux
" Just Friggin Wicked"
Now with TCM support...
AFR isn't in my fuel menu, which is why I posted the entire menu and what my choices areIll_Born_SS wrote:Commanded Throttle position (or Absolute Throttle Position - for older vehicles that don't have the Commanded parameter) = under THROTTLE menu
I have yet to try the dataviewer live, I can try it tomorrow.Ill_Born_SS wrote: Have you tried to view using dataviewer live thru your device. At the top in dataviewer find and select infrequently used PIDs and then re-populate the list. Some computers have the required PIDS for dlredux
you won't have the AFR/Equivalence Ratio parameter available for your old truck...
Your killing me06MonteSS wrote:you won't have the AFR/Equivalence Ratio parameter available for your old truck...
Does anyone if there is, or soon have an update for the GM gas trinity??
I checked the main site but I only see updates for other stuff, not GM gas.
