2009 Pontiac G8 GT custom tune
Speeddemon
Post by Speeddemon »
I own a 2009 Pontiac G8 GT with a L76 6.0L V8 engine. I am using a U7194 predator with 9r14 revision, and I was wondering if anyone might be able to email me a custom tune for it. I have installed a Magnaflow cat back exhaust and Volant cold air intake. Any help will be awesome.
"The Speed Demon"
RE: 2009 Pontiac G8 GT custom tune
no.. there is no "sharing" of custom tunes...
tune files are locked to a vehicles VIN and calibration ID's... so, you can not use someone elses custom tune file on your vehicle... you'd have to get a custom tune created specifically for YOUR vehicle, based on a copy of your tune file from your car.
if you'd like a custom tune done specifically for YOUR vehicle, then PM me for info, cost, files needed, etc etc...
Speeddemon
Ok, I have a local tuner so I'll just check them out.
"The Speed Demon"
well, if you want to be able to continue to use the predator so that you can restore the original backup stock tune at any time so you can take your car in for dealer service work, you'll need to make sure your "local tuner" is a diablosport CMR dealer/tuner and can create a custom tune for you...
and if he's not, then make sure you "restore original backup" to your car first before he tunes it, so that you start with the original stock GM tune and so that you unlock the predator... or you'll be screwed...
Speeddemon
The local tuner is a CMR dealer, I don't know if he would be willing to work on a car though because he deals with trucks mostly. Thanks for the help 06MonteSS.
"The Speed Demon"
Speeddemon
I'll probably do some datalogging and post it up to see what I can do right now though.
"The Speed Demon"
Speeddemon
Hey Lew, I think I'm going to see about having you do a tune for my car. I just need to some datalogging and I'll let you know.
"The Speed Demon"
ok man, sounds good...
you know where to find me... ;)
Yenko427
Post by Yenko427 »
I just got a Predator U7194 tuner and it came with a 9r11 on it. Is it safe to tune my G8 gt?
Speeddemon
Yeah, as long as it's 9r07 or later. I suggest to update to the 9r14 just to be safe though. Mine came with the 9r14 so I was alright.
"The Speed Demon"
Yenko427
Post by Yenko427 »
Its not letting me update to the 9r14. I downloaded it and I try to load it to the programer but the downloader said not responding.
Speeddemon
Is it a new predator? Of course it doesn't really matter as long as it's 9r07 or later.
"The Speed Demon"
Yenko427
Post by Yenko427 »
Ok im going to go install the tune to My G8. Thanks alot.
Speeddemon
Don't forget to do the original backup, just in case.
"The Speed Demon"
Speeddemon
I meant 9r08, but you should still be ok.
"The Speed Demon"
