Good pids to log for your tuner...
Posted: Thu Mar 04, 2010 2:25 pm
by johan
I have been asked this alot and here is breakdown on what I like to see as far as pids go in order to properly adjust a calibration.
I split it up in the two different groups for 05-06 and then 07-up and they are grouped by the groups they are listed in Predator/Trinty and Dataviewer.
Dashboards are attached for Dataviewer as well.
2005-2006 PIDS
EPDSS
RPM
rpm
Foundation Inputs
MPH
mph
Charge Temperature
ACT
F
Coolant Temperature
ECT
F
Desired Fuel Air
OPEN LOOP FA
FAR
Fuel Flows
1/1 Short Term ADAP
2/1 Short Term ADAP
1/1 Long Term ADAP
2/1 Long Term ADAP
BARO
kPa
PRATIO
PRatio
Injector Control
TOTAL WORKING PW CYL1
us
Knock Control
KNK LT RETARD
deg
KNK ST RETARD
deg
Spark
ACTUAL SPK CYL1
deg
BASE SPK
deg
MAP
SENSED MAP
kPa
MAP TO USE
kPa
READ MAP KPA
kPa
Miscellaneous
RAW TPS1
V
RAW TPS2
V
2007-up PIDS
Igntion
Base Spark
Deg
Actual Spark Cyl 1
Deg
Intake
Intake Air Temp Deg
F
Manifold Air Pressure
kPa
Barometric Pressure
in Hg
Injector Pulse Width Cylinder 1
us
Fuel
REQD FUEL CHARGE CYL1
mg/charge
Miscellaneous
1/1 Short Term ADAP
2/1 Short Term ADAP
2/1 Long Term ADAP
1/1 Long Term ADAP
DESIRED FA CYL1
FAR
OPEN LOOP FA
FAR
READ MAP KPA
kPa
P-Ratio MAP/BARO
PRatio
Misfire
KNK LT RETARD
deg
KNK ST RETARD
Deg
Performance
Vehicle Speed
mph
Engine Speed
rpm
Read Engine RPM
rpm
Throttle
Throttle Position Sensor Percent
Accelerator Pedal Position
Throttle Blade Position
Posted: Sat Mar 20, 2010 11:54 am
by searles_400
well this is noob question but i want to record my first log and send it in for you to look at so i know what to adjust. can you give me a quick run down of how to record it properly and then where do i sent the results
thanks
Posted: Mon Mar 22, 2010 10:48 am
best bet is to contact a CMR dealer for help....
Posted: Tue Apr 27, 2010 5:20 pm
by Moystro
Hi I bought a predotor from a friend, and its married to a jeep I have a dodge charger 2006 and use the same U7135, haw can I divorce these to the jeep and marry it to the charger?
Posted: Tue Apr 27, 2010 5:26 pm
by Moystro
Hi Im looking for some help,
Posted: Mon Feb 28, 2011 6:57 pm
by msmechanical
awsome material :)
Posted: Thu Feb 09, 2012 7:15 pm
by ViperGeek
I can't seem to find "DESIRED FA CYL1" under Miscellaneous in the Menu Map:
http://www.diablosport.com/beta/Predato ... enuMap.pdf
Is the original post outdated or perhaps the PDF?
- Dave
