map 13.8 psi
jrmybck
map 13.8 psi
Post by jrmybck »
map settings are now 13.5 with the wot fuel at -6, how much further do i need to go?
concoursd
RE: map 13.8 psi
Post by concoursd »
what do yo mean 13.8 psi? Why are you looking at manifold pressure?
jrmybck
RE: map 13.8 psi
Post by jrmybck »
i dont know. im looking for a fuel reading, and the only readings i have any where close to 12-14% is map. im trying to take my fuel to 12.8. only thing else close is tp angle. what am i supposed to be looking at. 2.04 series
concoursd
RE: map 13.8 psi
Post by concoursd »
not sure, I will let monte chime in. I think you may want to be looking for o2 sensor voltages and you would need to shoot for different values as ideal.
RE: map 13.8 psi
12.8?? so you're looking for a WOT AFR value???
then you need to get a wideband O2 sensor man... can't go my the manifold pressure for that... d'oh!!
jrmybck
RE: map 13.8 psi
Post by jrmybck »
where do i get a wideband o2 sensor. can i just leave my fuel at -5. my injector slope is -11. i didnt know what map meant in the diablo language. d'oh!!
