My New DataLog
redfoxsa
My New DataLog
Post by redfoxsa »
There is my New DataLog after i install Diablo Performance Tune on my Tahoe
Reference :-
Tahoe 2010 5.3L
Mod :
- Volant CAI
- MagnaFlow Cat Back Exhaust
5 x 11 x 22 in. Muffler, 3 in. Tubing; 3.5 in. x 5.5 in. Oval Tip, SINGLE REAR SIDE EXIT
Fuel used : 95 Octane
My Log is attached
RE: My New DataLog
damn dude... your ltft's are waaaay negative... at -20 to -22... you're running rich as hell....
gettin any trouble codes for anything??
redfoxsa
Re: RE: My New DataLog
Post by redfoxsa »
06MonteSS wrote:damn dude... your ltft's are waaaay negative... at -20 to -22... you're running rich as hell....
No Trouble codes
How can i fix that
RE: Re: RE: My New DataLog
got everything installed correctly when you put that volant cai in??? all hoses reconnected??
the MAF sensor is in correctly?? facing the right direction?? using their new washer they give ya for it?? and only their washer, don't use both...
redfoxsa
Re: RE: Re: RE: My New DataLog
Post by redfoxsa »
06MonteSS wrote:got everything installed correctly when you put that volant cai in??? all hoses reconnected??
every hose is connect right
There is no washer come with CAI
http://volant.com/edetail.asp?ID=638
volant CAI : No 15353
RE: Re: RE: Re: RE: My New DataLog
the volant's usually come with a new MAF sensor rubber o-ring...
I know they did for 08 and 09 GMC Sierra's - cuz I know a few people that have 'em...
maybe it doesn't for yours... the instructions don't say anything about it?
redfoxsa
Re: RE: Re: RE: Re: RE: My New DataLog
Post by redfoxsa »
06MonteSS wrote:the volant's usually come with a new MAF sensor rubber o-ring...
Nothing about O Ring in instruction
http://volant.com/3dkls/iddb/Tfile/FILE ... /15353.pdf
i will send to Volant technical support and see what they will say
RE: Re: RE: Re: RE: Re: RE: My New DataLog
nah, that's fine then...
I checked the instructions before too... yours doesn't have it...
it must have that new "power core" filter... the one that looks like a bunch of plastic straws stuck together lol...
have seen others with that new power core filter have the similar issue like you... but they're ltft's weren't THAT low... they were only down to like -14...
so, you are probably fine judging by others I've seen and that powercore filter track record...
redfoxsa
Re: RE: Re: RE: Re: RE: Re: RE: My New DataLog
Post by redfoxsa »
06MonteSS wrote:nah, that's fine then...
That is true i use power core filter ......
So, How can we fix that ??
Do i have to change the filter Or .....
RE: Re: RE: Re: RE: Re: RE: Re: RE: My New DataLog
nah... do the steady cruising data log, and then adjust your slope accordingly and you'll be fine...
or if you're going to have me do a custom tune for ya anyway, you can just do the log and send me everything I need, and I'll do it in the tune file...
redfoxsa
Post by redfoxsa »
i think serious to remove the VOLANT CAI
back to the stock Air Intake
Return to “Trinity GM Gas”
