Error Validating File ?
eortiz
Post by eortiz »
2006 SRT8 Charger - Installed the per CAI 93 octane tune - went well.
Went to Modify Stock tunes - did the temp changes - rev limiter in drive 6600k raised shift points - proceeded to install tune now - erroe message read - ERROR VALIDATING FILE - wHAT im I doing wrong? Is Per 93 CAI tune different from Modify STOCK tunes?
Help me !!!!
RE: Error Validating File ?
WHAT REVISION ON THE PREDATOR?
eortiz
Post by eortiz »
Good morning Mike -
I didn't go to work today too tired trying to make this work til 2 am..
I bought this tuner 4-15-10 from Maryland Speed but first time installing it yesterday - just read the 14 day return policy-
Installing the 93 CAI went well - but modfiing parameters, I make all changes fan settings limiter when promt to install now - it reads Error valadating file - this morning I updated the tuner from your website from 9R22 to 9r23 - tried it again same results - what is error code U0101?
eortiz
Post by eortiz »
Is something defective with the tuner or I doing something wrong?
eortiz
Post by eortiz »
Serial # 280209 U 7135 2006 SRT8 Charger
eortiz
Post by eortiz »
I'm sorry to chain email you - but I tried to modify parameters at least 20 times...
eortiz
Post by eortiz »
DS -
Any suggestions?
Been waiting patiently - want to install my adjustments..
OK, lets try to get this unit swapped out if possible.
I am not familiar with this issue and would like to test this unit here on the bench.
eortiz
Post by eortiz »
ok - what should I do?
Send it back to Maryland or to you?
eortiz
Post by eortiz »
Shipping ddress
Ed Ortiz
Pepsi-Cola - Vending Dept
1400 W. 35th
Chicago, Ill 60651
17738428668
Unit U7135 serial # 208209 purchased from Maryland Speed on 4-15-2010
I could FedEx the unit tomorrow overnight delivery.
Contact Maryland speed, Brandon should be able to help you out.
If not, fill out the rma request and we'll fix it asap.
eortiz
Post by eortiz »
I left 2 email on the customer Contact link - they dont have a phone number - no response yet.
I waited a whole year for this Prediator always a reason why I couldn't afford it - I just bought it one day and now I'm catching hell from the old lady.....just kidding she is awesome and supportive!
eortiz
Post by eortiz »
Just talked to Maryland Speed - all is good sending a replacement -
Thanks for everybody's help on this...
eortiz
Post by eortiz »
Recieved the replacemnt unit -
and the screen is still reading ERROR- the same error meassage "error validating file" only when trying to install modifyied tunes -
(fan settings - rev limiter - add the options sub menu under the Modify parameters)
I looked into the car on board CPU and the date is July 5th 2005 version V4.06 pn 04843155AF. I bought this car back in Oct 2005.I'm sure this was one of the first early build of SRT Chargers released. Do you think the electronics CPU is not compatible with the Prediator. Is there an option to purchase a custom ready tune prepared by DS with the per 93 oct. with CAI with modified options shift limiter to 66k, temp setting low side 185, temp setting high side 195, raised shift points.reset transmission all under one tune? Instead of trying to modify under modify parameter which don't accept with my car? Kind of tricking the unit to accept tune all in one command?
what is the revision on the Predator?
