srt4 lt fuel -33 and st -20 any help
waynekopp
Post by waynekopp »
my 05 srt4 is pulling 2 much fuel at idle long term is -33 and short term is -20 and my a/f are 13.5 at idle and around same under boost. I have checked everything i can think of upstream 02 map sensor iac sensor and tps sensor and there wireing. any help please. the only way i can get it to stop pulling fuel at idle is creat a vacuum leak but my a/f is still reading the same. I am lost.
RE: srt4 lt fuel -33 and st -20 any help
have you changed injecotrs, or MAP/TIP sensors?
waynekopp
Post by waynekopp »
yes and no. This is all happening on a stock tune with stock injectors and map and tip. I have bigger injectors and 3 bar map and tip buy tune shop told me i need to get this problem fixed first cause they couldnt fix it with a tune.
exhaust leaks?
bad O2 sensors?
waynekopp
Post by waynekopp »
Well the car has the 3 inch down pipe from turbo and then 3 inch to a turn down under car with no cat. There are no leaks as there is not much to leak. The upstream 02 has been replaced as thats the one i was aware that controled that. The other 02 as fare as i know is just for the cat whitch is not there. There are no codes in car. I am lost and dont know what else to check as i have checked everything i know of and some things twice. I cant even enjoy car or what the diablo will be able to do for car as it is not running right.
duster360
Post by duster360 »
Post a log using these PIDs: http://www.srtforums.com/forums/f384/wh ... og-484265/
include idle and part throttle cruising. Be sure the engine is fully warm and use the STOCK tune
Needless Torque Calibrations
www.needlesstorque.com
waynekopp
Post by waynekopp »
will do as soon as i get a chance as i can not get the driver to work on my computer so i have to use a friends
ptperformance
Post by ptperformance »
How many miles on the car? You could have a plugged fuel filter/regulator. If you have a bad o2 sensor normally the ST fuel trims will not adjust so I suspect that is not the problem.
I see that this is a few months old so I hope that you got the problem fixed.
