Loose Internal Connector Wire
Posted: Sun May 23, 2010 6:07 pm
Alrighty, as I griped about a looong time ago, my Predator long ago decided that it didn't want to continue connecting to my truck, so I decided to try to figure out why.
Apparently, one of the connector wires being fed into the circuit board connector came loose. The yellow one on the end, to be precise. As far as I can tell it's not the only one loose, yet also as far as I can tell, there's no way to put it back in.
Might anybody know the particular model of the connector piece used in the 2007 SUV U7194 from the 06-07 model? Also, where it can be purchased?
Or it would be wonderful if Diablo volunteered to send me the piece.
Or if someone wanted to give a quote on how much it would cost to send me a whole new connector cable (OBD-II Port connector to MOBO connector) that'll work too.
Also if it helps, the wire pattern is White - Blue - Green - Brown - Yellow
