06 Dodge 6 speed stock clutch
ncyz1v
Post by ncyz1v »
any one else haveing truble with the stock clutch???
which clutch would you recomend?
ncyz1v
RE: 06 Dodge 6 speed stock clutch
Post by ncyz1v »
The south bend OFE or the 2 disk one????
I hear the FE is not good for towing...I tow 25K weekly....
Does any one out their have a diffrent brand they are happy with???
From my research South Bend is the best but hey 1250.oo+ shipping is not cheep...
Nick,
Smart Line products
06 Dodge 6 speed,4x4 dually on 265/70/19.5's
predator POWER!!!
95' dodge diesel with 165k that sounds better than my 06?
Dodgezilla
Post by Dodgezilla »
I just got a South Bend Con OFE rated for 450hp. I made exactly that on the dyno a couple weekends ago and it does not slip at all even on the Extreme RKL tune. Ya, it's not cheap but no clutch is going to be cheap for these trucks...
04 Ram 2500 RARE Timberline Green 4x4 305/555 CTD/Stock48RE,DS Predator,VA C3.2,HE351 turbo, 2nd gen intake, BHAF,Custom 4" exhaust, More stuff....
madmanwithmouse
Post by madmanwithmouse »
my stock doesn't slip that I can tell but if I pound on it with any of the regular tunes it seems to lock in and when I push the clutch it doesnt want to go down, Iv'e got to relly push on the clutch pedel to get it to release.
2006 Dodge Ram Cummins 3500 Dully, 4x4, Manual trans:
Predator/Puck, Fass 95 Pump, 4" Turbo back Straight pipe, K/N, Quadzilla moniter and boost fooler, Intake baffle delete, Modded airbox
http://www.dieselbombers.com/index.php?referrerid=1849
NEVERENOUGH
Post by NEVERENOUGH »
madman, it sounds like you may be burning/melting the clutches together. You WILL have to get an aftermarket clutch if you run the higher tunes especially if you tow. I havent met anyone yet who could honestly resist the power :mrgreen: ........................
Dodgezilla
Ya, that's strange!!! It's hard to explain how a slipping clutch feels but it's definitely not like that!! Pony up man and get it........;)
ncyz1v
Post by ncyz1v »
madmanwithmouse wrote:my stock doesn't slip that I can tell but if I pound on it with any of the regular tunes it seems to lock in and when I push the clutch it doesnt want to go down, Iv'e got to relly push on the clutch pedel to get it to release.
That is exactly what mine does....If I push it.Then i put on the 19.5 with 35's on the truck and tow 20K...it even does it on the TOW mode now...
YES IT IS a must.I just wanted to hear if there was a better one than South Bend out there?
I sell motorcycle parts and clutches and think i will become a South Bend dealer.....
We all need one if you have a stick.....and 10% off to all members sounds good to me how about you guys?
I found a guy who spent $2300.oo installed that's just WRONG!!!
The SB Con OFE seems to have a bit of grabbiness on take off.For the first 2k miles.From what i have heard anyway.
Nick,
Smart Line products
predator POWER!!!
Dodgezilla
Yes it is a bit grabby upon take-off but you get used to it. You also need the solid flywheel and upgraded hydraulics. I got mine done for a lot less then $2300.00!!! Wow!!
Anyways, I also get some vibration from the solid flywheel but it's not bad at all. Just a bit more than the dual Mass flywheel but I was expecting that. If I get tired of it I'll shell out for a Fluid-damper but I don't think I'll reach that point....
The OFE is the lightest duty of the SB clutches. Get an FE or a DD and you will definitely feel some grabbiness and a stiff pedal....
ncyz1v
Post by ncyz1v »
Dodgezilla wrote:Yes it is a bit grabby upon take-off but you get used to it. You also need the solid flywheel and upgraded hydraulics. I got mine done for a lot less then $2300.00!!! Wow!!
How many miles do you have on the clutch???
and hw bad is the vibration....oh and have you pulled a hevy load with it yet?
Nick,
Smart Line products
predator POWER!!!
NEVERENOUGH
ncyz1v, You should go ahead and get you one especially since you have the added mass of the 19.5's. The vibration is caused because the flywheel being solid it cant absorb the vibs the clutch causes when its being "grabby". It wont be that bad and besides you nobody else would probably notice it that much.
ncyz1v
Post by ncyz1v »
NEVERENOUGH wrote:ncyz1v, You should go ahead and get you one especially since you have the added mass of the 19.5's. .
Which one though???? OFE or DD....South bend said the DD would not jerk as much as the OFE....but I realy do not know???
List ofe 1000.00
List DD 1900.00
+ 250 to upgrade clutch master cyclinder!
I just want to get the right one the first time!
Nick,
Smart Line products
predator POWER!!!
NEVERENOUGH
I say if you plan to use just the predator/puck with and occasional use of the rkl's i would go with the SBC OFE and save a little $$, if you think you will one day get into heavier mods i would definately go with at least a SBC FE if not the street version of the SBC DD. I personally am not a fan of the OFE (1 organic/1 feramic) style i like the FE (full feramic), like you stated "do it right the first time". Just my $.02. Try and get with Dodgezilla as his current is a manual and i believe his last truck was too.
Dodgezilla
My last truck was an auto and it had a DTT trans in it. You are right about everything else you said though ;). I know a guy who had a DD in his 500+hp 05 and he ended up pulling it out and getting an FE. He hated that DD clutch!
I have not towed with the new clutch yet. It has around 700 miles on it now....
