predator RKL stacker tunes
Posted: Sun Jul 08, 2007 6:45 pm
by dieselram_04
hey anyone else having issues with the predator RKL stacker tunes causing bad rattle at 1500 rpms when cold? issue goes away once temps hit 150. runs great once its warmed up. tried both stacker tunes full timing and less timing. only other fueling mods are GDP 392 and edge juice with attitude but i can turn the juice to stock or all the way up and it netiher helps or makes it worse. any ideas?
RE: predator RKL stacker tunes
Posted: Mon Jul 09, 2007 1:33 pm
by duallydave
do a search o here,some other guys said that too when cold,mine doesnt but i have heard it before.whats a gdp 392?
Posted: Mon Jul 09, 2007 1:41 pm
by dieselram_04
sorry its a glacier diesel lift pump when it starts rattling and you give it more gas it starts popping and sputtering like its running out of fuel.
Posted: Mon Jul 09, 2007 6:51 pm
by Dodgezilla
It's giving you some timing advance right off the bat and that combined with the engine being cold will cause that rattle. Just go easy on it until it warms up. No big deal. I had the same issue with a Quadzilla Race box on my 03 CTD....
Posted: Mon Jul 09, 2007 8:19 pm
by NEVERENOUGH
In my opinion you should not be in the throttle enough to hear the "cold knock". I let my truck completely warm up EVERY time it starts. Think about this, i have been well over 600hp for almost 75k miles when it melted a piston last month. I drive it like its yours............. LOL BUT, EVERYTIME i start my day or if it has sat enough to cool to ambient i let it idle at 1100rpm for around 3-5 min. I would like to believe that helped me see the mileage i saw at that power level. Treat her right and she will be nice to your pocketbook.........
Posted: Mon Jul 09, 2007 8:34 pm
by dieselram_04
i do let it sit and idle for about 3 mins and when i do get in it and take off i drive it like theres a egg on the accelarator. no matter how light i push the throttle i still get a rattle and my valvebody is set up to shift right at 1500 at VERY light throttle which is where the rattle starts.
Posted: Mon Jul 09, 2007 8:36 pm
by NEVERENOUGH
Well i dont know then. Try longer. It is 85-90* here in the morn though. Winter (Houston LOL) is a little longer.
Posted: Mon Jul 09, 2007 9:55 pm
by Dodgezilla
I'd try pulling the Juice completely off and see how it does....
Re: predator RKL stacker tunes
Posted: Mon Jul 09, 2007 10:07 pm
by ropnjessi
dieselram_04 wrote:hey anyone else having issues with the predator RKL stacker tunes causing bad rattle at 1500 rpms when cold? issue goes away once temps hit 150. runs great once its warmed up. tried both stacker tunes full timing and less timing. only other fueling mods are GDP 392 and edge juice with attitude but i can turn the juice to stock or all the way up and it netiher helps or makes it worse. any ideas?
Mine does the same thing on the rkl tune, it does run great when warmed up though.
