predator RKL stacker tunes
dieselram_04
hey anyone else having issues with the predator RKL stacker tunes causing bad rattle at 1500 rpms when cold? issue goes away once temps hit 150. runs great once its warmed up. tried both stacker tunes full timing and less timing. only other fueling mods are GDP 392 and edge juice with attitude but i can turn the juice to stock or all the way up and it netiher helps or makes it worse. any ideas?
- duallydave
RE: predator RKL stacker tunes
do a search o here,some other guys said that too when cold,mine doesnt but i have heard it before.whats a gdp 392?
04 l/box.predator quad race x2 cammander.bhaf.6spd stick.
dieselram_04
Dodgezilla
It's giving you some timing advance right off the bat and that combined with the engine being cold will cause that rattle. Just go easy on it until it warms up. No big deal. I had the same issue with a Quadzilla Race box on my 03 CTD....
04 Ram 2500 RARE Timberline Green 4x4 305/555 CTD/Stock48RE,DS Predator,VA C3.2,HE351 turbo, 2nd gen intake, BHAF,Custom 4" exhaust, More stuff....
NEVERENOUGH
In my opinion you should not be in the throttle enough to hear the "cold knock". I let my truck completely warm up EVERY time it starts. Think about this, i have been well over 600hp for almost 75k miles when it melted a piston last month. I drive it like its yours............. LOL BUT, EVERYTIME i start my day or if it has sat enough to cool to ambient i let it idle at 1100rpm for around 3-5 min. I would like to believe that helped me see the mileage i saw at that power level. Treat her right and she will be nice to your pocketbook.........
dieselram_04
NEVERENOUGH
Dodgezilla
Re: predator RKL stacker tunes
Mine does the same thing on the rkl tune, it does run great when warmed up though.dieselram_04 wrote:hey anyone else having issues with the predator RKL stacker tunes causing bad rattle at 1500 rpms when cold? issue goes away once temps hit 150. runs great once its warmed up. tried both stacker tunes full timing and less timing. only other fueling mods are GDP 392 and edge juice with attitude but i can turn the juice to stock or all the way up and it netiher helps or makes it worse. any ideas?
03'/305 Dually 4 x 4
Platinum FASS/150,/Level II CP3, 60hp.Inj.
Stage 1 cold air box, BD Intercooler
Smarty SSR,62/65/13ss, CFM+
Goerend Trans. Westach, Fuel/Rail Gauges
2011 Laramie Longhorn All Stock
