On the 2010 Ram 5.7(87 or 93 tune) is there any way to allow
hpc3
Post by hpc3 »
less "nanny" function on initial throttle ie from a stop if I give it 80-100% throttle the throttle body application compensates and shuts the tb until sufficient speed is achieved for WOT throttle. I was under the impression that all the torque management aspects were allowed to be more aggressive with the tunes and these latest files are every bit as conservative as stock from a stop.
Also, and maybe I missed these, but where are the disable for ESP and other changes on the Ram? I did find the tire size option today but nothing else. Any guideance appreciated.
u7137
9r07a
2010 Dodge Ram Laramie 4x4 Hemi.
CL8N
RE: On the 2010 Ram 5.7(87 or 93 tune) is there any way to a
Post by CL8N »
Wish the DS came with torque management and ESP disable. Kind of disappointed about this. Thinking of going to a Super Chips
2010 Crew-Cab Sport 2WD
SC does not have either of tyhose options, nor timing and fuel adjustment...
doz
Post by doz »
SC does support removing torque management now actually. One of the only reasons I might go with it. Im really hoping DS gets on the bandwagon (even if at an additional cost like SC) and allows it to be modified. I really want the timing/fuel adjustments though too (although TM removal is huge).
hpc3
Post by hpc3 »
Yep, SC has a way to lessen the TM stuff. Trying to get one to play with before I need to send the Predator back.
doz
Post by doz »
Well mike PM'ed me back saying they remove a good bit of it.. Im just wanting it gone, and if predator can remove enough of it by default, thats all im looking for. Still tranny tuning would be nice to be able to change shift points.
Re: RE: On the 2010 Ram 5.7(87 or 93 tune) is there any way
doz wrote:Well mike PM'ed me back saying they remove a good bit of it.. Im just wanting it gone, and if predator can remove enough of it by default, thats all im looking for. Still tranny tuning would be nice to be able to change shift points.
If you decide you want more removed, email me the tune and I'll set it up.
pullthis
Post by pullthis »
I want the rev limitor removed can you do that?
hpc3
Post by hpc3 »
Mike can I try this as well? This is on the 06/07/10 - U7137 9r07a.crom, 93 tune. Let me know and thanks for any consideration.
have you tried raising it with the predator?
email me a copy of your last tune written and original backup.
pullthis
Post by pullthis »
mikel wrote:
pullthis wrote:
mikel wrote:If you decide you want more removed, email me the tune and I'll set it up.
yes I have and it couldnt be raised above 5800, asked about it on this forum and was told at the next revision. I sent it back and I wait!!!
So fix it already I have abunch of truck pulls coming up!!!
CL8N
RE: Re: RE: On the 2010 Ram 5.7(87 or 93 tune) is there any
Post by CL8N »
Superchips does offer torque management. I know that the Diablo is the preferred choice for a lot of cars, but it doesn't seem to be for the new Ram :( Are you guys planning on adding torque management in the future? This is a huge restriction on the 4th generation Rams. Also, it doesn't allow me to adjust my RPM's on my 2010. Heard there was supposed to be a revision for this also. Any news on that?
Guys, it seems the point is being missed, TM is reduced in the canned tunes to the point that there would beno need for an adjustable TM parameter, unless you wanted to add some back in for some reason.
hpc3
Post by hpc3 »
I'm still waiting on a tune with TM reduced more. I don't care if its adjustable or not, just want more throttle control than the truck/tunes currently allow. Any word on revised tunes Mike? 9r08 doesn't seem have anything on reduced TM.
