Logging mph vs. Rpm
bucsfan368
Logging mph vs. Rpm
when i do my log with the program dslogredux it says to be in the 1800 to 2500 range but in order for me to get to the range i have to drive like 80mph just to hit 1800 rmp's. what is a good speed with the rpm in mind?
I don't think speed matters. It's the RPM range you need the most. In my experience, I haven't noticed much diifference in the LTFT results doing different speeds that fall within the recommended RPM range.
2000 Chevy Silverado 1500 Z71 4WD ECSB 5.3L
U7198 ver 9r17
Diablew Tuned
K&N CAI
Corvette Servo
U7198 ver 9r17
Diablew Tuned
K&N CAI
Corvette Servo
Re: Logging mph vs. Rpm
Don't know what your ride is or if it is stick or automatic, but drop down a gear or two if necessary to get your desired rpm. Just make sure you keep the rpms as steady as possible.bucsfan368 wrote:when i do my log with the program dslogredux it says to be in the 1800 to 2500 range but in order for me to get to the range i have to drive like 80mph just to hit 1800 rmp's. what is a good speed with the rpm in mind?
RE: Re: Logging mph vs. Rpm
either drop down a gear so you can hit 1800-2000 rpm...
or...
post up the log you have currently and I'll check it out and letcha know what to do...
or...
bucsfan368
bucsfan368
yeah, log looks fine... I'd go +1 or +2....
and you're at 1800-1850 rpms at 70-72mph... which is fine too...
bucsfan368
