Lew!! Help, Data Log infomation 07 Silverado 6.0L Gas
reredrider
Post by reredrider »
Does this look like I am doing it correct? I s advises to adj inj slope down by 3%. See attachment. Thanks for the help...
RE: Lew!! Help, Data Log infomation 07 Silverado 6.0L Gas
log looks good... you logged the wrong throttle parameter tho...
you wanted to log the Commanded Throttle Position for your newer truck/predator... not the absolute throttle...
reredrider
Ok, I will change the throttle issue. How do I get the attachments to you to make the custom Tune?
PM sent...
Bsims50
Post by Bsims50 »
Dude you are running extremely lean. the air fuel ratio should be around 12.5 to 13.3 when you hit the gas i jumped up to 16. 14.75 is where all the gas and air burn perfectly. you will see more power running a little bit richer. Im guessing around 5-7RWHP. I have a 07 Silverado 5.3L with around 400RWHP.
hahaha!!
did you look at the whole log??? he's not lean... he wasn't going WOT... max throttle was 67%... not even into WOT/PE mode....
he had let off the gas from a steady cruise, and his rpms dropped to 574-584... for 1-2 seconds.. hundredths of a second... and the afr bumped up... as soon as he gets back on the gas pedal, AFR is normal... all is normal operation... no issues here....
and no worries... he's gotten a custom tune since then anyway... ;-)
