2001 Firebird - U7198 - 9r15 - WOT Datalogging
Posted: Wed Jun 30, 2010 4:56 pm
by Whitehawk489
How come i cant datalog WOT with the U7198?
RE: 2001 Firebird - U7198 - 9r15 - WOT Datalogging
Posted: Wed Jun 30, 2010 5:07 pm
whats keeping you from doing it???
Posted: Wed Jun 30, 2010 11:32 pm
by Whitehawk489
sorry im asking in the wrong place. i was refering to datalogredux. just wondering why wot isnt available with the u7198
Posted: Thu Jul 01, 2010 8:49 am
by 06MonteSS
because that class II predator tool does not log the AFR (equivalence ratio) parameter.... that's any class II predator tool, 7192, 7193 included - it's not just the 7198's...
you'd need to use a laptop and the dataviewer program to do a datalog, and then you'd have the AFR (equivalence ratio) parameter available to select via the dataviewer...
Re: RE: 2001 Firebird - U7198 - 9r15 - WOT Datalogging
Posted: Fri Jul 02, 2010 11:13 pm
by Whitehawk489
06MonteSS wrote:you'd need to use a laptop and the dataviewer program to do a datalog, and then you'd have the AFR (equivalence ratio) parameter available to select via the dataviewer...
thanks for the help! are you saying i need the laptop in the car? ive already used the datalogging to help adjust my ltft's. im just looking to what else i can do with my tuner. attached is my last ltft log.
RE: Re: RE: 2001 Firebird - U7198 - 9r15 - WOT Datalogging
Posted: Mon Jul 05, 2010 2:49 pm
by 06MonteSS
yes.. you would have to connect the predator to your OBD port in the car... then connect the laptop to the predator via the usb/serial cable... then use the dataviewer program on the laptop to select the parameters to log and do the logging...
