PLEASE READ BEFORE POSTING
When posting in the Predator or Trinity support forums, please include:
Make, model and year of vehicle
model # of Predator or Trinity
software revision on the Predator or Trinity
specific information relating to any issue or question you may have
This will allow us to assist you more efficiently.
RE: PLEASE READ BEFORE POSTING
I have a trinty t1000.I own 2010 Dodge Challenger also own a 2002 Dodge Ram 1500.The Trinty goes back to 2003.Can i down load 2002 for my Ram?
no... 2002's are not supported by the Trinity at this time...
hello. I recently purchase a trinity T-1000 from a friend. and im having trouble to install it into my car dodge neon srt-42005. It says :
(3) the tool is not licensed for use with this vehicle...... please tell me what to do. thanks
Tell your friend to reinstall the stock tune on his car.
I have a trinity t1000 for 2008 Jeep Grand Cherokee 5.7. I reset some settings on my 93 oct tune, and now my tuner keeps telling me that I need to unplug it to cycle power so that it can reboot for the internal update. I've been doing this unplug, let it set (sometimes for a whole day) and it still tells me that an internal update needs to be completed and to unplug breifly to cycle power for the reboot to be completed. Has anyone else had this issue?
dodge_sst1
Re: PLEASE READ BEFORE POSTING
2011 DODGE RAM 1500
5.7 Hemi
Trinity t1000
ser# 6K1PFF6-1
Part #dcx_gas
ver#v.1r09c
Calibration 68057118AF not supported by dcx_gas at 1r09c comes up on calibration down load page under DS Downloader2.2.2.6
trinity shows this is needed when plugged into truck.
5.7 Hemi
Trinity t1000
ser# 6K1PFF6-1
Part #dcx_gas
ver#v.1r09c
So download the new Cal. www.diablosport.com/dcx has directions.
The Trinity Update at http://74.205.121.176/spages/supportdoc ... rinity.pdf is unavailable.
i have a 2011 dodge ram 1500 hemi. my trinity arrived day before yesterday. i downloaded all the updates, put it in the truck and it said it needed another update. I did that one and it let me do the 91 octane tune. today I did the 93 octane tune with no problem. later i went to change the tire size and that failed. i tried to reinstall the 91 octane tune and modify it. first i did the throttle at 10%, that tune failed to load. then the i tried the 93 octane load again and only modified tire size, that too failed. is this just teething issues because the ram was a recent add ? should i just wait a couple weeks and get an update ?
thanks
scott
thanks
scott
speedrules1
I have the trinity t1000 and just updated it and it now says error pcm unlock -1 when I try to install tune? 08 chrysler 300 C I first did the install of the 93 oct cai with modify for fan settings and shift firmness and throttle boost and it worked installed then I went back in and tried to modify tire size and it failed several times so I went in to check that the right vehicle was chosen and reentered the info I then restored the backup and started over but now get error pcm unlock -1??
BryanMcnasty1967
do yall sell an a-post mount for the trinity for a 2011 dodge ram 1500
daytona2103
I have a 2006 dodge charger daytona rt and I installed the trinity t-1000 with the mpg booster tune and now I cant unlock/lock my car from a distance. I literally have to put the key to the window and click it a few times before it unlocks/locks the car. What is this?
2006 Dodge Charger Daytona Top Banana #2103/4000. KOOKS LT headers. Catted mids. SLP LM1. K&N CAI. Trinity T-1000.
try moving the location of the trinity. it sounds like there is electrical interference with the placement of your trinity.daytona2103 wrote:I have a 2006 dodge charger daytona rt and I installed the trinity t-1000 with the mpg booster tune and now I cant unlock/lock my car from a distance. I literally have to put the key to the window and click it a few times before it unlocks/locks the car. What is this?
I have a 2014 dodge charger rt
Installed the 91 octane tune
How I adjust the shift firmness?
Thanks,
Rick
Thanks,
Rick
