U7170 - Economy tune and adjusting speed limiter
Posted: Tue Jul 13, 2010 1:57 pm
by HHB
I have a U7170 (v.7r19d) and normally run the 65 hp tune for economy on my '02 Ex 7.3. However, I would also like to be able to adjust the speed limiter such that I can set it lower when others are using the truck.
Is it possible with the tuner I have?
RE: U7170 - Economy tune and adjusting speed limiter
Posted: Tue Jul 13, 2010 2:19 pm
Lower it?
Not with the Predator, but we could write a custom tune to do it.
Posted: Wed Jul 14, 2010 1:22 am
by HHB
Excellent. How do I go about placing the order and how much would a custom tune be?
Posted: Wed Jul 14, 2010 9:58 am
No charge for the speed limiter tune, export a copy of your tune and post it here...
Posted: Mon Jul 19, 2010 7:00 am
by HHB
Hi, it is now somewhat more complicated. I had the truck in to the dealer for some adjustment and I loaded the original tune back before I took it in. Now the dealer has done some changes, and I have probably made it worse with trying to bring it back. When I read the VIN with the Predator it shows a different serial number (lloks like the serial number of the programmer the dealer used). Can I load the original backup which is stored on my Predator to bring the truck back to to where it was? Can I just load it in or do I need to do something special.
Posted: Mon Jul 19, 2010 10:25 am
If you loaded the stock tune befroe you went to the dealer, then there is nothing to load...
Sounds like maybe you did not restore the stock tune first??
Posted: Mon Jul 19, 2010 12:08 pm
by HHB
I was hoping the original tune was stored in the Predator even when I loaded the stock back in the truck before I took it to the dealer. When I downloaded the files to my PC I got one that was called backup.frd and one called tnaa4y2.frd. Both are 256kb. Can any of those be used? How can I check?
Posted: Wed Jul 21, 2010 4:24 am
by HHB
I now got everything sorted out and the 60HP Predator tune loaded back in the truck.
To add the speed limiter adjustment you asked for a copy of the tune. Which tune do I post? Is it the original backup or do I read off the 60 hp that is in the truck now?
Also. Is the 60 hp tune the best economy tune for a stock 02 Excursion 7.3? I bought my Predator in 2006.
