Want More
Posted: Thu Jul 12, 2007 6:09 pm
by mustangsn95snake
I have an 07 Ford 6.0 diesel! I have the predator currently on the 100 hp setting and I want more! I will give another post with the cali id. I want an all out race program it currently has a cold air and plans for a turbo back and better intercooler are coming! Thanks!
RE: Want More
Posted: Thu Jul 12, 2007 6:14 pm
by mustangsn95snake
And I have that problem with 2290 too so if you could incorperate that into the program as well!
Re: RE: Want More
Posted: Fri Jul 13, 2007 9:37 am
by cole
mustangsn95snake wrote:And I have that problem with 2290 too so if you could incorporate that into the program as well!
I would suggest on some fuel upgrades as well. p2290 is causes when commanded injector pressure kpa is greater than actual kpa supplied to the injector. There is also an amount of kpa error which allows the + or - the amount of error. Some cases both fuel filters need to be replaced and the truck tested again. But its an actual issue with commanded injector pressure which we can correct.
Re: RE: Want More
Posted: Sat Jul 14, 2007 6:18 pm
by mustangsn95snake
Re: RE: Want More
Posted: Sat Jul 14, 2007 6:20 pm
by mustangsn95snake
RE: Re: RE: Want More
Posted: Sat Jul 14, 2007 6:21 pm
by mustangsn95snake
The truck is brand new theres only 4,500 miles on it I would not think it needs a fuel filter yet also what can I do to the fuel system to upgrade it!? My cali id is VXCF4S3 so can you get me the tune that fixes 2290 and give me the tune I originally asked for I talked to your rep and he said that you guys have an all out race program (150 hp) Thanks!
Posted: Sat Jul 14, 2007 8:10 pm
by mustangsn95snake
Ok found the program VXCF4S3 figured out how to put it on the tuner went to put it in my truck and this came up: custom tune will not be used it does not match original tune for vehicle. tune for this vehicle is c9a871a6:7c1598d2 please help if there is something im doing wrong let me know! Thank you!
Posted: Sat Jul 14, 2007 8:41 pm
by jackgf250hdsd
mustangsn95snake,
what's up? I got the same msg. I think you might have to restore original backup, its what i did and then put in the modified stock tune which i think is the custom 100hp tune.
we won't know until monday when cole is back in the office. I just got back from Orlando and i was avg. 21mpg highway, what kind of mpg are you getting??
Posted: Sun Jul 15, 2007 9:25 am
by jackgf250hdsd
hey snake,
forget my last msg. that was not it as far as the modified tune. i just reloaded the 100hp tune and works fine. have to wait for Cole on monday.
Posted: Sun Jul 15, 2007 10:38 pm
by cole
mustangsn95snake wrote:Ok found the program VXCF4S3 figured out how to put it on the tuner went to put it in my truck and this came up: custom tune will not be used it does not match original tune for vehicle. tune for this vehicle is c9a871a6:7c1598d2 please help if there is something im doing wrong let me know! Thank you!
Please export a copy of your original backup to the PC first then also make sure you have the COMPRESS SEND button checked on DSDL software. Then send the custom tune to the predator. It will send properly and show up in the predator under custom tune menu.
Posted: Wed Jul 18, 2007 1:04 am
by mustangsn95snake
And how do I do that I been messing with all night cant figure it out please help step by step I am new to this game!
Posted: Wed Jul 18, 2007 8:11 am
by mustangsn95snake
I found were it said export original back up. when I tried to export it said go to performance tune to continue! please help me step by step! :?
