Will not shift from first to second in WOT
2006 Jeep Commander 5.7 HEMI, Predator u7137
So had a lot of difficulty getting my programmer up and running. But finally figured it out and I'm now up and running. However, when in WOT, it will not shift from 1st to 2nd. It will just slam the rev limiter. It will go all the way to 6500 before the pcm cuts the throttle. However it shifts good from 3/4 throttle.
RE: Will not shift from first to second in WOT
What revision is the Predator on, and what tune are you running, also post the original backup and last tune written and someone will take a look at it.
http://www.tpctuning.com
Did you raise the shift points or anything?
I have not driven it since I re-installed the tune. I'm running the latest update. I have it on 93 octane performace.
Still doing the same thing. I re installed the stock tune, and re installed the 93 tune and still the same thing.
Re: RE: Will not shift from first to second in WOT
mikel wrote:Did you raise the shift points or anything?
- fighterjet_05
have you changed WOT shift points?fighterjet_05 wrote:have you fixed the problem with the rev limit? Mine is doing the same thing.
If so, change them back to stock.
- fighterjet_05
- fighterjet_05
does it shift OK when you restore the stock tune?
- fighterjet_05
