power puck problem need a part
PowerPuck/Extreme PowerPuck Support
motoman006
Post by motoman006 »
ok im missing the plug that goes into the toggle switch, it has three wires white brown and green, and the switch is a 4 prong switch, i need to know where the wires go, or if i can get a new male end for the switch here is two pictures
help me out please!! see i have the female end (the switch) but its missing the male end to plug into the switch i just got the switch from you guys today
Image[/list]
RE: power puck problem need a part
you only need the 3 wires you have shown.
motoman006
so hook them up and ignore the yellow wire correct? ill try and see what i can do thanks again mike
can you also tell me which way is 60hp and which way is 90?
Return to “PowerPuck/Extreme PowerPuck”
