Gear Change Question
Posted: Thu Aug 26, 2010 11:42 am
by Brad519
I've got the Predator U7194 I'm using on my 2008 Chevy Silverado and I'm changing the gears next week. I've been told you can use the predator to change the gear ratio setting but I was unable to locate it on the predator. Is this possible and if so where is the gear setting. Thanks in advance for any help.
RE: Gear Change Question
Posted: Thu Aug 26, 2010 11:49 am
This will require a custom tune.
Export your tunes and post them here and I'll set you up.
Posted: Fri Aug 27, 2010 12:11 pm
by Brad519
Hopefully I did this correct.
This is on a 2008 Chevy 4wd 5.3 currently running 3.73 gears and switching to 4.88 gears. Need a tune for the new gear ratio.
Posted: Fri Aug 27, 2010 1:53 pm
by johan
See how this one behaves.
Posted: Fri Aug 27, 2010 2:17 pm
by Brad519
Ok thanks. Gears will be installed Monday so I'll put the new tune in when I get the truck back.
Posted: Wed Sep 01, 2010 4:41 pm
by Brad519
Appears to have worked fine.
Speedo is correct again.
Thanks Again for the help.
Posted: Wed Sep 01, 2010 4:57 pm
Sweet, thanks for the feedback.
