U7186 9r12 vs 9t12e
U7186 9r12 vs 9t12e
I see the latest update in the update section as 9r12 but keep reading about 9t12e. What is the difference? I have a '06 LBZ with Rev 20 installed.
2006 Silverado 2500HD ECSB LBZ 4" MBRP exhaust, Blockerplate and Fingerstick, U7186 Predator, Kennedy Booststick, Isspro EGT and Boost gauges, S&B Intake.
RE: U7186 9r12 vs 9t12e
same...
Do not load r12 it will screw your tuner up. I did and still waiting for a fix.
Thanks for the heads up. I'll keep watching this to see how it works out.
Northernbuddy
Problems with 9r12 update
I have a 2007 DM LLY. I tried to update the programer with the latest update but get the following error message: CROM u7186-9r12. Incompatible hardware.(no serial falsh found). Contact tech support...
I see others have had similar problems, what is the fix
