chevy 2500 lmm
chevy 2500 lmm
just got x puck for 2010 lmm p#2030 plugs dont seem to match anyyhing pics are unclear n manuel i have trinity on this truck already would like to add the puck but cant seem to find out if I ned to reload factory tune first or just install puck over t1000 thanks
No need to do anything with the Trinity.
On the LBZ & LMM engine the MAP Sensor is located on the front air intake manifold tube on the front of the engine.
On the LBZ and LMM engines the Fuel Pressure Sensor is located on the back of the fuel rail on the passenger’s side of the engine. The connector is the same as the connector with the orange grommet on our wire harness. You will need to connect to the sensor and the factory connector.
- (3.04 MiB) Downloaded 554 times
- (3.04 MiB) Downloaded 596 times
It should just be futher back on the fuel rail.
confirm the correct torque spec on that valve, I believe it is 100 ft/lbs.
did you check the torque on the fuel relief valve?
are you trying to run the extreme tune with the puck turned all the way up?
the extreme tune adds almost as much power as the fuel system will wupport, so you may be limping it by adding too much and not getting the commanded fuel.
Try a lower tune or try the stock tune and see how the puck works by itself.
