06 duramax 0087 code
dmax10214
Post by dmax10214 »
I have an 06 chevy duramax that keeps throwing a p0087 code (low fuel rail pressure) when it first started throwing it was only when I was pulling a trailer over 8000# then went to setting it off with any load NOW no load just easy driving sets it off! It doesn't matter what tune i have or back to stock I always set Predator U7186 tuner to the correct tune when hooked to a trailer I had injector pump checked its ok I had injectors checked bypass flow too high on all replaced ALL injectors STILL sets code any suggestions
Trotorx2
RE: 06 duramax 0087 code
Post by Trotorx2 »
Have a look here: http://www.duramaxdiesels.com/forum/sea ... id=1669909
Could be a few things. Search engines are your friend! :)
2006 Silverado 2500HD ECSB LBZ 4" MBRP exhaust, Blockerplate and Fingerstick, U7186 Predator, Kennedy Booststick, Isspro EGT and Boost gauges, S&B Intake.
